Question about Kettler Giro GT Indoor Training Bike
My speedometer stopped working where should I look to see if maybe there is a loose connection?
Where is the speedometer connection ? I want to see if something is loose or disconnected but not sure where to look, I think there should be a connection to the pedal or wheel but ist does not show it in the manual, does any one know where I should look'
Sport Trac. Speedometer, tachometer, and odometer stopped working 98 percent of the time. Why do they work randomly?
might be a bad connection behind the dash the connector for instrument panel maybe loose
Nov 21, 2015 | 2004 Ford Explorer
Does a 2008 dodge caliber have a speedometer fuse
if it's cable driven then the cable may have broken, if electrical then maybe loose connection or bad earth
Apr 17, 2013 | 2008 Dodge Caliber
Speedometer
your speedometer has possibly come loose where it connects to the trans. You can follow the line to where it connects to the trans and see if its loose or came disconnected.
Aug 27, 2012 | Cars & Trucks
2006 yamaha r6 headlights dont work and speedometer light dont work but all fuses are good
Sounds like it could be a fuse for the speedometer light and the head light or maybe just the fuse for the speedometer and the lightbulb maybe bad also check for loose wires
Jun 18, 2012 | 2006 Yamaha YZF-R6
Speedometer stops working once in a while
check for a loose wire at the back of the cluster, it will look like it is still in the connector but it is not all the way in, I forgot witch pin it is but it is in the middle row or bottom and about the 5-8th pin from the left, Hope this helps
Mar 05, 2010 | 1998 Ford Explorer
I just purchased my sonata. While driving my
Possible Vehicle Speed Sensor (VSS) problem, or a loose connection at the VSS.
Is your Check Engine light on? Are there any fault codes in your computer?
Nov 01, 2009 | Hyundai Motor 2004 Sonata
2001 Chyrsler T & C speedometer stops working
sonda to me you have a bad connection at the gauge when you push on it it makes the connection for a while after a few bumps in the road it looses it's connection. pull the instr.panel check your conncetion. if not replace gauge. hope this help's
Jan 13, 2009 | 2003 Chrysler Town & Country
perhaps a vehicle distance sensor located in transmission however if you have a check engine light on I would hook it up to a OBD 2 scanner to retrieve the fault code gue$$inglis not the way to go! the vehicle might have 2 of these sensors Vehicle input and output sensor be sure to check the speedometer cable to see if it is still functioning internally that would be totally mechanical!!! cable with in a cable! hope this helped you out!
Dec 31, 2008 | 1995 Dodge Dakota
Speedometer works intermittently
other than maybe a loose connection idk about your speedo problem, but your belt problem, you should check all of your pulleys, make sure none of them are seized, or starting to go out.
Oct 20, 2008 | 1996 Nissan Pickup
Won't shift out of low,speedometer doesn't work
see my comments, not 100% sure that it was the out put speed censor or not, but after reconnecting the wires to a new censor and reconnecting the battery and clearing codes it worked. connection was not clipped may have been loose
Oct 05, 2008 | 1998 Dodge Intrepid
Kettler Giro GT Indoor Training Bike Logo
26 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
