Question about Pantech Breeze III
Phone gets hot charging
Phone seems to over heat when charging
Vivaz gets hot
Most phones become hot when used for a long time. If the phone is getting heated during charging, thats normal. but if the phone heats up in minutes of a call then you need to take it you a repair centre. If you have Warranty, it will be a good idea to take it to the poit of purchase.
Oct 02, 2013 | Sony Ericsson Cell Phones
My iPhone 2g is heating up..and if i charge it its so hot and i will take me 1 day to fully charged it and if not fully charged i can used it up to 20-30 munites if fully charged 2-3 hours and the hot...
You either have a bad battery or you have a bad charger. If the phone heats up when you plug it into the USB port on a computer then you know that the battery is bad and needs to be replaced. If the phone does not heat up and you get a normal charge from the USB connection then you know that the battery is good and the charger is bad.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
Phone is not charging and is getting very hot
hi this is a good sign the battery needs replacing if you take your phone into a phone shop and just ask them to see if it needs a new battery or not they wont charge just to have a quick look at your phone but the chances are the battery just needs replacing if its getting hot then this is a sign the battery isnt holding any charge causing it to over heat.
This is a common problem with most phones.
let me know how you get on or if you need further assistance ok
Feb 16, 2010 | Cell Phones
Extreme over heating
This is NOT good, I have actually heard of phones actually catching FIRE, truly, this is not a great idea. ALL equipment needs air flow around it at all times, especially though, when charging. Too much heat in any event will prematurely kill the unit.
Feb 07, 2010 | Motorola Mobility CLIQ Cell Phone
No battery backup
then dont charge the battery too long and charge for daily one hour. and the battery may be damaged that so you get the heat problem
Sep 21, 2009 | Nokia E51 Cellular Phone
LG VX8300 will not make or receive calls.
If it's getting hot - the battery is bad. Once the battery heats up, they can become a fire hazard! Seriously - I know it's kind of funny, but replace the battery. This will probably solve your "not holding a charge problem". You can usually get a battery on ebay for around $5. And usually you can turn around and sell the phone on craigslist for $50 once you get your new one.. <BR> <BR>
If it doesn't get signal with a new battery - the internal antenna is probably faulty - this will happen if it's been dropped one too many times, or had some other sort of hard impact.
Mar 20, 2009 | Cell Phones
Battery gets hot and won't hold a charge; plus shattered LCD screen
the glass and LCD can be fix and replaced but the main-board heating up is saying that the board needs to be replaced but you should just purchase new one.
Jun 26, 2008 | Motorola Mobility RAZR V3
Motorola i870
One or more part are getting hot in your phone due to short circuit. Water damaged phones normally have this problem. Battery gets charge but it discharges quickly for that leakage. You can try yourself. Disassemble the phone. Put out the main PCB and connect Battery. Now observer which parts are getting hot. Clean the PCB properly and change that parts if you can.
May 19, 2008 | Motorola Mobility i870 Cellular Phone
My K810i suddenly became very hot. It wasn't near a hot surface or in ant direct heat. I took out the battery, which was very hot. After a while it had cooled down. On replacing the battery and trying to...
Chances are that your battery has fried. But before you buy a new one try leaving the battery out of the phone overnight. Then put it back in the phone and plug the charger in. Even if nothing seems to be happening leave it plugged in for a few hours. Sometimes, it takes a bit of time till the charging begins (I have seen this happen on rare occasions). Worth trying before you buy a bew battery.
Mar 24, 2008 | Lands Phones
Lcd heat
it seem like water must have entered the set get it serviced
Aug 23, 2007 | Motorola Mobility RAZR V3
Pantech Breeze III Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
