Question about Dacor Microwave Ovens
Power supply cord
Only show 44 volts between the blades at the end (where it enters the inside the back of the unit). Is this normal?
  • Dacor Master
  • 9,639 Answers
No. Measure the volts at the wall socket to see if it's correct. If it is then look at a new power cord.
Posted on Mar 20, 2014
  • 3 more comments
  • Kevin Ring
    Kevin Ring Mar 25, 2014
    After I posted the question, I found that when I tested each blade with the other probe on a ground point they each tested 120v.
  • Lawrence Oravetz Mar 25, 2014
    if you get 120 volts to ground you have a dangerous condiition there. you should have 120 between blades not from blade to ground.
  • Kevin Ring
    Kevin Ring Mar 26, 2014
    I have 120v at the receptacle. Also at the mid plug inside the rear box, but only 44 at the blades. It would imply a bad power cord. However that cord shows full continuity from start to finish on each blade. Could it still be a bad cord?
  • Lawrence Oravetz Mar 26, 2014
    Instead of checking continuity on the cord check the resistance of each conductor in the cord. If it's ok then some part inside is dragging the voltage down. Are all the fuses inside good? Where exactly ate you measuring 44 volts? What are you connecting the probs to that gets you that reading?
  • Kevin Ring
    When I checked the resistance of each conductor in the reading was 0.0 for both. My voltage reading was between the two blades at the end of the cord, with the cord removed from the unit. These protrude just inside the unit when the cord is screwed into the back of the unit. The fuses are all good (monitor, magnetron temperature fuse, conv. thermal cut out). The unit shows 120v at the control unit relays when I put one lead on the relay blade and one on a ground screw. When unit is plugged in it is completely dead.
How to find fuse
Elaine, it will be inside the outer housing of the microwave. Un-plug the power cord and then take out the screws holding the outer cover on, some may be a special "torx" screw which will take a special tool to remove them. The fuse will be right near where the power cord enters the back of the unit. Usually goes to a small circuit board and the black wire typically connects to one end of the clip that the fuse snaps into. Hope this helps.
Mar 31, 2014 | GE XL1800 1100 Watts Microwave Oven
No power. outlet is good, microwave plugged in. no lights, no power, nothing. does this unit have a power supply that might have gone bad?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
My sharp grill2convection made a noise and quite working. is this possibly a fuse?
Regards.
Nov 06, 2011 | Sharp R-930AK Convection/Microwave Oven
No power to microwave outlet funtioning properly
Best wishes.
Nov 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker light blew and now wont turn on
Regards.
Ge spacemaker jvm1650sh01 has no power after power outage
Regards.
Nov 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar 2006 doesn't work at all ,no power
Regards.
Walesarumi
Sep 29, 2011 | Microwave Ovens
No power in microwave, replaced fuse and still nothing
Regards.
Walesarumi
Sep 26, 2011 | Microwave Ovens
Regards.
Walesarumi
Sep 26, 2011 | Kenmore Microwave Ovens
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
