Question about Directed VB271 Car Video Player
No sound My battery died now I don't have sound
2006 Ford 500. Good battery power. clicks when ignition is turned( sounds like low voltage ) car died while driving. Won't restart. Fuel pump??
You might think the battery is good,but it might be weak or alternator going out. Check battery connections also. don-ohio
Feb 13, 2017 | Ford Cars & Trucks
2003 Forenza - brake + battery warning lights turn on and off
sound like alternator faulty.remove it let auto parts store person check it out.
Jul 29, 2013 | 2006 Suzuki Forenza
93 lebaron died while running, now clicks when being jumped.
From what you describe, my guess is that eventually you will replace the starter
Apr 24, 2013 | 1993 Chrysler Lebaron
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Our phone at work just went dead no dialing tone no nothing.. what can we do to solve this problem? please help.
Sounds like the batteries died on the UPS. First replace the batteries. Check the fuses. dust of the UPS. it this don't work email at ericpettingill@hotmail.com and I will more info to help diagnose the problem
Sep 19, 2011 | Eaton 3XXGP9170B9SLCX UPS System
I don't know what is wrong with my car the belt just recently broke and we had to replace it but before we did that the battery died when we were driving and we killed the battery trying to get the car...
sounds like it may be a bad alternator. jump start the car and if it gets going disconnect the negative battery cable and if it dies you have a bad alternator. It may die as soon as you unplug the jump start cables.
Jul 28, 2011 | 1997 Nissan 200SX
My nokia 2690 is not getting started (on) & not supporting the charger also.its not getting charged.
It sounds like your battery has died. The batteries don't last forever and they eventually start to hold less and less charge. Did you notice the battery starting to last a shorter and shorter time? You probably need a new one.
Jul 22, 2011 | Cell Phones
My v551 don`t charg. I test the charg volt and is 6 V.i plugged in the conection but dont beggin the charg
How old is the battery? It sounds like the battery has died and needs to be replaced. I suppose it is possible there may be corrosion on the connections that need cleaning. If it is new enough you should contact the manufacturer.
Jan 30, 2010 | Motorola Mobility V551
Battery is fine but I get a clicking sound before it dies. Van will not start. What could it be? alternator or starter? How do I tell? Thanks, Don
Your car problem is of (SELF) its coil must have gone broked .. get that fixed .. thank you for asking
Jun 24, 2009 | 1993 Nissan Quest
Directed VB271 Car Video Player Logo
41 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
