Question about Kenmore Washing Machines
No I did not. It would not let me type in the box when two different people came online. I tired everything and I still couldn't type.
  • 15,935 Answers
Please address your issue to experts@fixya.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
2008 hilux diff ratio
need lots more information to determine exactly what the manufacturers ration would be
manual and auto have different ratios as do diesel against petrol have different diff ratios
go google and type in --www.vehicle mods.net.au and you will find a toyota hilux drive train gearing bible that covers the years 2005-2015 it explains everything including different tires and the effects on ratio readings
I found it by going google and typing in--toyota hilux diff ratios ---
Jun 24, 2017 | Cars & Trucks
What is the proper tire pressure for P235/70R15 on Chevy Blazer
32-35 psi cold or hot air pressure usually has a 2-3 lbs difference...See Owners manuel or tire man. recommendations..
Feb 24, 2015 | 2001 Chevrolet Chevrolet Blazer
Wrong tire size?
P designates a tire for a passenger car, 225 is the width of the tire in mm, 75 is the ratio of sidewall height to the width (eg thesidewalls are 225*0.75=168.75 mm tall), R is the type of tire (radial), and 16 is the diameter of the tire in inches. Customizing the tires gives you different performance results.
If you want your car to act according to how the manufacturer specified, go back to the stock tires. However, your current tires have a larger diameter than the stock, which means your rims are also larger than stock; you would probably have to replace the rims as well, which can be expensive.
I would stick with your new sizes. Different sized tires will not harm your vehicle in any way. I would also recommend going to a store that offers lifetime warranties like Les Schwab; they are invested in insuring that that everything is fitting correctly so they don't have to refund you anything.
Feb 14, 2014 | 2001 Jeep Grand Cherokee
My light came on the one shaped like an engine and my car shakes in the front when i go 50 n over firestone couldn'[t find the problem
Could be your inner or outer tie rod ends or tires, you might try a reputable local independent garage rather than a big box tire store. Independent Service & Repair facilities tend to have more knowledge and experience then tire stores...and are more affordable!
Apr 19, 2012 | 2004 Chrysler Sebring
I have 2004 jaguar xj8, i locked the glove box and i couldn't i try many time but is not working.
THE LOCK MECHANISM IN GLOVE BOX COMPARTMENT CAN BE REPLACED THE LOCK HAS A SCREW THAT HOLDS IT IN PLACE THE GLOVE BOX.
Aug 12, 2011 | 2004 Jaguar X-Type
I have a Gio 500w ebike. The tube inside the back tire needs to be replaced and I cannot find the size to buy anywhere.The Gio website sells them but dont give u the size. I was also told that you can...
Hi! I have 2 Gio Scooters. I looked and looked for a tube for my tire and couldn't find a place until I realized that if you go to Ebay online you can actually buy them through Sven the supplier who sells the Gio Scooters on Ebay. You can just buy them from him and pay through paypal. Make sure the valve is curved and not straight out or it's not the right one. He ships pretty fast too:) I hope this has helped. It took me awhile to get parts. He also will ship parts, he's out of Vancouver. So Good Luck:) Do you know anything about fuses for these bikes???? Grrrr....
TTYL.G
Jun 15, 2011 | Health & Beauty
Dont remember the code for the remote to my television
Hello
Try with these codes. These codes are of universal remote control with Apex Digital.
015 226 037
May 10, 2011 | Apex Digital AT2702 27" TV
Bandsaw tire part #41815, where to buy?
A bandsaw tire is usalley defined by the size of the saw. A example is a 12" x 80" bandsaw means that the wheel (tire) is 12" and the blade is 80" . If you are unsure just measure the wheel size.
Then go online and type in (example) 12" bandsaw tires.
You will soon see that there are a few different choices in material , the stock ones from sears are cheap but will do the job. Then there are the poly orange ones that cost more but don't slip like the stock ones.
Also type in bandsaw tires on YouTube this may help because changing them can be a pain.
Hope this helped, I asked the same questions when I got my first Saw years ago and am glad to pass it on. If this helped I would apperciate a comment.
Thanks,
Shop Dog
Feb 17, 2011 | Craftsman Saws
Load grinding noise in front tires; thumping also when you apply the brakes.
I went to have my tires on my 2002 4x4 Ford Explorer rotated and balanced then noticed that the fronts had significant inside wear so I replaced them. The rear tires were still in the 65-75 range. When I left immediately I heard significant whinning and thumping coming from the front end. Took it back and they said it was coincidence and I would have to take it to a shop that specializes in front end repair. I have a really close friend that owns a reputable shop and after 3 days he couldn't look at it long enough to determine the issue, even though he thought it was either a transfer case or possibly torque converter. I decided to work on it myself. The whinning started at about 35 mph and increased significantly when releasing the gas. After researching heavily and on the verge of giving up I saw a couple of threads that someone with similar issues just had tires with more than 1/4 difference in circumference. My front end felt like it was literally falling apart, so that couldn't be it, could it? So I did a simple chalk test by placing a mark at the bottom of the tire and roll the SUV for 10 revolutions and checked to see if there was any difference... Yes there was, but at this point I was still a nonbeliever that something this small could cause a vehicle to act the way it did.. So the front driver side chalk line matched the driver rear chalk line and the same on the passenger side. So I swapped one side drove it and BAM it was fixed, sure was better that the quote I was getting for the repairs from a friend 500-1400!!!! Do yourself a favor and try this!!!!!!
Jan 31, 2011 | 2003 Ford Explorer
Washing Machines Logo
14 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
