Question about Coleman 1997 Fleetwood Sunridge Refrigerator Vent Door Cover Pop Up Camper
Set on unbraced bed, it poped out but nothign is broken how do we get it back in
The metel stop is in the way of just slideing it back in
I want to buy my daughter a bed with a slide that gets you from the bed to the floor. Where can I get one?
Those kind of beds are great fun. We bought one and the kids love it. Here's a link to the walmart site for an example. http://www.walmart.com/ip/Girl-Twin-Loft-Bed-with-Slide/17472908
Sep 12, 2012 | Furniture
HOW CHANGE THE FUEL PUMP
EITHER UNBOLT THE BED, UNPLUG THE WIRES & SLIDE THE BED BACK TO EXPOSE THE TOP OF THE FUEL TANK OR REMOVE THE TANK. I PREFER MOVING THE BED
Nov 19, 2010 | 1998 GMC Sierra
Clock in radio will not display or radio station number will not display on my 1999 jeep wrangler am/fm tape player. radio only displays the numbers 1 thru 9. the radio and tape player both work.
I won't sware this will cure yours but I took the front cover off mine and where the little metel slot things plug into your radio i took some steel wool and cleaned and shined them up. The cover should come off by gently prying on the ends. Mine even had a spring that when you pushed on it it poped out a little. But becareful not to pry to hard. If it won't budge the get someone who can help you pull it off. You should see the metel contacts that almost look like you could take it out to prevent theft of the radio. Let me know if this helped. Just a guess mind you. Please no bad marks, Good Luck, Raz
Apr 17, 2010 | 1999 Jeep Wrangler
I have a '93 coleman, cedar tent trailer with a broken rear bed. The bed extends through the end of the track and comes off the rail. I'm looking for a diagram, parts list, and repair advice.
I have the same issue. It looks as though the rivets broke off. I have yet to reattach the slide mechanism. Normally the slide mechanism is stopped by a peice of emtal about 1./2 the way down the slide. Either new rivets or some flush head screws might sole your issue.
Oct 19, 2009 | Coleman Sport & Outdoor - Others
Process to change fuel pump on 2001 chevy silverado 1500
take the six bed bolt loose and then take three buddies slide the bed back put in the new pump slide it back n place and put the bed bolts back in. if u drop the tank u can easily break the hard plastis lines that go to the fuel tank. u only have to take the fill lines and taillight wires loose this way its alot quicker, and easier.
Jul 29, 2009 | 2001 Chevrolet Silverado 1500
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Coleman 1997 Fleetwood Sunridge Refrigerator Vent Door Cover Pop Up Camper Logo
Top Coleman Home Experts
Donni Steen
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
