Question about Garden
Bolens st160 My electric drive has stopped working , got a stick in the wires it worked when i wriggled the wires ,now theres nothing
Windshield wipers not working
blowen motor sticking motor or check wiring to motor incase the wires are touching and blowing fuse
Feb 24, 2014 | 1996 Dodge Ram Pickup Truck Carpet...
Volkswagen sharan
probably has another Brocken wire cheack all the wiring that you can and then go from there
Jan 18, 2014 | Cars & Trucks
Bolens st140
If you have a manual check for all their safety features such as seat. If the seat has an electrical plug connected to it, bypass it and see if it starts. Do the same thing with any other safety features to eliminate that problem. There are times when safety switches stick, make sure if button operated, that button moves freely in and out. Check to see if you have current going to starter to determine if the problem exists between ignition and starter.
Jun 08, 2013 | Garden
None of my break lights are working...i changed the bulbs and thier still not working..what could it b?
Check on your brake pedal there is a switch on there thats what actually makes your brake light come on when you step on pedal
Feb 17, 2013 | 1997 Dodge Caravan
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
My headphones have stopped working. the plug attached to the left headphone seems to have disconnected as when i wriggle it sound comes through intermittently
there is nothing you can do but open the casing and cut the wire as close to the solder as possible then solder it on again then they will be like new again its a really easy job
Jan 31, 2011 | Bose On-Ear Headphones
Why does my acelerator stick when i stop
Do you have a stop on it that stops it from coming up? Is that where it is sticking? Mine used to stick up there and drive me nuts, go to step on the gas and nothing, I put a little baby powder on it and it worked fine. Check it out.
Mar 19, 2010 | 1987 Peugeot Liberte
CAR WON'T START EVERTHING WORKS LIGHTS RADIO IT WILL RUN A CAN DRIVE IT FOR A COUPLE A DAYS THEN IT WON'T EVEN TURN OVER PUT EVERYTHING COMES ON I CAN WRIGGLE SOME WIRES BUY THE BATTER AND PLAY AROUND WITH...
Are your battery termnals clean and tight. If your able to correct the problem by moving wires, consentrate on this area for bag connections and correct them.
Jan 18, 2010 | 2000 Ford Taurus
Need wiring diagram for bolens model 800 garden tractor
Bolens is made by MTD products.You can contact them directly od thru their distributor Dixie Sales cover the entire east coast and are great to work with
Nov 14, 2009 | Garden
1998 Dodge Ram 2500 - hit sticks in the road
You must have ripped the wires off underneath your truck, and you probably don't have brake lights anymore either. Better get somebody to repair it as soon as you can.
Jun 04, 2009 | 1999 Dodge Ram 2500 4WD
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
