Question about Stoves Ovens
How to i set the clock on an omega europa OA25
I cant set the clock. is there a manual for this wall oven.
SOURCE: omega europa 40-1 oven settings?
I had the same problem when I moved into my current apartment (mine's the 20-1 model). I was at a loss as to what all those symbols meant, so emailed info@hagemeyer.com.au and they sent me a pdf copy of the manual. It's not exactly the same model as you have, but I assume the symbols are the same. I'm happy to email you my manual if you'd like. Otherwise, the controls (for the 20-1 at least) are as follows:
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
I hope that all makes sense.
Posted on May 12, 2009
SOURCE: Timer will not go back to 0 / Light below oven setting remains on
Try and get the timer to zero, as soon as the timer is on zero the light under the oven setting knob will turn off.
Posted on Jun 25, 2009
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
rickead1
  • 1998 Answers
SOURCE: need user manual for Omega
you can go to this link and get the manual from contactin directly to the company or you can list your model number and i can try for you here is the link if you choose to do it yourself http://www.omegaappliances.com.au/Default.aspx
i think your best off going to the manufacture because they will give you one for free where as other places might charge you please remember to rank how this post helped in your appliance situation and if there are any futher questions i can answer for you please message me back have a great day
rickead1
Posted on Aug 22, 2010
SOURCE: Omega Europa 20-1 oven. What do the symbols mean?
Posted on Jan 23, 2011
Where can I get a user manual for an Omega Europa 14-1 Oven?
Search the internet for:
Make + Model + the word "Manual"
Apr 29, 2016 | Ovens
Omega OA 25 oven auto turn off?
Is there a way to change from "Fan Forced Oven" to normal conventional heating oven in an Omega OA25 model?
Jan 14, 2012 | Ovens
How do I turn my omega oven europa 60-1 on? I turn the knobs, the electric clock is flashing but nothing comes on?
Can anyone tell me how to turn off my omega europa 60-1 oven. I have put both temp and fan to off but oven fan still going Help please as cannot find isolating switch thanks
Oct 08, 2011 | General Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
My omega europa oven is not heating up .grill fan
Mar 18, 2010 | Ovens
Oct 03, 2009 | Ovens
Omega europa 40-1 oven settings?
Apr 12, 2009 | Ovens
Ovens Logo
152 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
