Closed captioning doesn't work on Vizio M470sl
Closed captioning works on my roku 3 hooked up to my sony tv but it does not work as stated previously on my vizio
SOURCE: My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
Posted on Jan 10, 2009
  • 14 Answers
SOURCE: I can not get closed captioning on my vizio VO42L
If you are using a HD cable box then this would be setup in the cable box itself.
Example:
With a Motorola Cable box, you would turn it off and press the menu button (with the receiver off and TV on). This will bring up a menu that will allow you to adjust your digital closed caption settings.
If you do not have a Motorola cable box that I would refer to the manual or call the cable company.
Posted on Apr 05, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
  • 92 Answers
SOURCE: hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
Posted on Jun 16, 2009
smarthome2
  • 1114 Answers
SOURCE: hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
Posted on Aug 08, 2009
What symptoms will a bad tv board/tuner cause
That does sound like the most likely issue is you MAIN PCB. You will need your complete model/serial# then see the following web site:
https://www.encompassparts.com/model/VIZM470SL/_/_/VIZIO/M470SL/47-INCH_120HZ_EDGE_LIT_RAZOR_LED_LCD_HDTV
Mar 11, 2015 | Vizio M470SL 47 in. LCD HDTV
How do get closed caption Vizio VF550M 55 in. LCD HDTV?
Closed Caption availability may depend on the source. To enable caption viewing, press Menu (on the TV or the remote). Navigate to the Setup menu with the Up/Down arrows on the remote or the Channel Up/Down buttons on the TV. Once Setup is highlighted, press the Menu button again. Repeat the up/down navigation to the CC menu and Menu to select. The first option should be On/Off. Now use the left/right arrows on the remote (or volume up/down buttons on the TV) to choose the desired CC state. Press Menu to save or Last to cancel and return to the previous menu. Press after pressing Menu to return to the previous menu. If your content is from a digital source, you can make adjustments in the appearance of the captions by navigating to those sections of the CC sub-menu. If you would like some idea of what the screen will look like as you navigate the On-Screen Display, see the manual on Page 41. Vizio makes the manual available on their support page. The direct link to the manual is cdn.vizio.com/documents/downloads/hdtv/VF550M/155Manual.pdf . (Note: you'll need Adobe Reader or a similar program to access the manual.)
For some content, you may need to enable the captions at a set-top box (cable/satellite receiver/etc.). In that case, consult the manual for those devices or post a comment with the make/model for additional help.
I hope this helps.
Feb 13, 2015 | Vizio Televison & Video
I would like to get closed captioning when I watch streaming netflix
Hi Shane,
Captioning is a function of the Roku box itself. Here's a FAQ from Roku to help you get it working. Good luck!
Roku Closed Captioning Help
Apr 07, 2014 | Sony Televison & Video
Netflix closed captioning
cant find the closed captioned for Netflix on tv not on computer.
for on the computer, it has C.C on TV
Jan 03, 2014 | Vizio Vbr334 3d Blu-ray Player With Wifi,...
Subtitle choice grayed out on vizio e390i-a1
You are confusing subtitles with closed captioning (CC).
May 13, 2017 | Vizio E390i-A1
How to closed caption on mute vizio
Hello -
The remote control for your Vizio TV probably has a Closed Caption button. Is there a button with CC printed on it? If so, that is most likely the button to press for Closed Captioning.
Dec 23, 2017 | Vizio 42 in. LCD TV
My Vizio VA19L 19'' LCD Television's closed captioning isn't working. The closed caption isn't on the settings menu either. How can I get closed captioning on?
Just press the CC button on the remote. Some TV stations may not send out CC data. Pressing the CC button many times will cycle thru all the options including OFF.
Mar 05, 2011 | Vizio VA19LHDTV10T 19 in. LCD TV
Vizio closed caption
Do you have a cable box hooked up to the unit? On the tv it is quite easy. The directions are located on .48of the manual. Here is an exert it from it is located here:
http://vizio.com/documents/downloads/hdtv/VL420M/254User_Manual.pdf
Thank you,
Lee
Mar 04, 2010 | Vizio VL420M 42 in. HDTV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
Jan 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
