Question about Viking VWH3048 Kitchen Hood
Damper noiseonly makes noise when its windy
A clanging noise occurs when it's windy
What would be causing a rattling/clanging noise coming from the left front wheel area when going over rough roads or road imbedded reflector on a ve commodore
broken spring top. damaged damper. steering idler. bearing plate lose. steering link damaged. would need to jack up that side at test every thing in list. could also be something lose in the side part behind the plastic covers. like a droped spaner
Sep 24, 2013 | Cars & Trucks
I can hear the wind blowing extremely noisy from my gas fire /chimney
It is not likely blowing from the fireplace, rather your hearing outside wind noise through the chimney pipe.
On windy days this is normal.
The noise can only be limited by the flue pipe damper and the length of the pipe.
Apr 14, 2013 | Heating & Cooling
GE washer makes clanging sound during wash cycle
What is the model number of the unit?
Nov 02, 2012 | Washing Machines
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
Makeing a loud tumbling noiseon truns
Those sorts of noise on turns usually means the CV joints are failing. A flexible joint that allows the drive wheels to move up and down and turn while powering the car.
Feb 09, 2011 | Lexus ES 300 Cars & Trucks
For some reason my AC started making a clanging noise. Upon checking I found that the blades went flying off the fan. How can I fix this
need a new fan blade. might want to check out your local wholesale parts store. make sure you take unit model # and s#
May 23, 2009 | Haier (HPE09XC6) Air Conditioner
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Viking VWH3048 Kitchen Hood Logo
71 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
