Question about Samsung Bn59-01041a Remote Control
How to adjust color on the tv
Remote
How do I adjust color on my Sony tv with Shaw universal remote?
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Once it is setup, press the TV button on the Shaw remote control, and press the MENU button. That should show the TV's "setup" menu.
Jan 22, 2013 | Logitech Harmony One Advanced Universal...
How to adjust color without remote
If your TV has a 'Menu' button on its front panel, you can enter its menu using it, and come towards picture adjustment window, and can change the intensity of color. If there is no such button on its front panel, you must have its remote control to do this.
Aug 27, 2012 | Emerson ET-14J2 13" TV
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
Jan 03, 2011 | Televison & Video
The remote does not work and the tv will not accept an universal remote.How can I adjust the color, brightness, contrast, and etc. with out a remote. The screen is dark and can not be adjusted without a...
Tries press the tv menu button on the tv front frame bazel to select color,brightness,contract so on...Adjust ur setting.Try website like remotes.com to buy an a exact to the original remote.
Oct 20, 2010 | Panasonic PV-20DF63 20 in. TV/DVD Combo
We dont have the tv remote and can not adjust the colors very well?
It may be a pain in the rear to do, but if there are buttons on the tv itself, you may be able to manually program./adjust the colors from the tv buttons. there should be one that will get you to menu and then select appropriate one to adjust contrast. other than that you will have to contact the mfg to request another remote, or refer to owners manual to see if it can be done. outside of this, if you know anyone else with the same tv, borrow their to adjust YOUR tv...
Oct 17, 2010 | Mitsubishi WS-48315 48" Rear Projection...
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
Jan 06, 2010 | Televison & Video
Pioneer Pro-200 60" Rear Projection Color Adjustment
after market duplicate remotes are reasonably priced-search tv remotes on-line.
Sep 26, 2007 | Pioneer PRO-200 60" Rear Projection...
Cant locate or adjust the the TV color
All the controls should be accesed thru the on screen menu,your remote should have a menu or display button and if you press it on the screen of the tv you should see a list of different options ,I am not familiar with the kind of menu that your set has but I know the color adjustment should be in the same screen that allows you to change the brightness,shapness,tint,color and contrast,the more you use the menu and become familiar with it the easiest it will be to use.Let us know if you need more information.
Nov 06, 2006 | Sony KV-32S26 32" TV
Samsung Bn59-01041a Remote Control Logo
15 people viewed this question
Jerry Greenberg
Jerry Greenberg
