Question about Sunbeam Cafe EM6910
No water coming through
Problemstarted after descaling
    Problem Solver:
  • 15 Answers
Depending on if this is HW or Group water... But if you did not clean teh shower screen and group first; you have loosened scale and it is caught in the HW change over valve.
Posted on Sep 28, 2014
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
Saeco talea giro plus
Yes it sounds like the pump is clogged with scale.
Oct 26, 2016 | Saeco Coffee Makers & Espresso Machines
I now use soft, filtered water each day. The "descale" message still comes up every 60 days. Is descaling that frequently, normal?
yes you will still need to descale it
soft filtered water still contains minerals and calcium but in lesser quantities
if you wish to avoid descaling use distilled water or demineralized water
Sep 18, 2016 | Breville Coffee Makers & Espresso Machines
Why the coffee is not coming out of coffee spout?
  1. If you can get steam/water from your steam spout.
  2. Fill your tank and add descale solution.
  3. Descale according to the instruction for the unit.
  4. After descale and rise are complete refill your water tank.
  5. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Jun 30, 2015 | DeLonghi EAM4000 Espresso Machine
Descale
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Cant remember how to de scale
Instructions per De'Longhi:
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing, it is time to descale the machine.
NOTE: when the light switches on, the coffee maker can still be used to prepare coffee.
Proceed as follows:
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers.
Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite.
• place a container with a minimum capacity of 34 oz. under the
cappuccino frother;
• turn the machine on by pressing the button.
• wait for the green and indicator lights to come on steady.
• press and hold the button for at least 5 seconds. The decalcification warning light will illuminate to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn counter-clockwise. The
descaling solution will come out of the cappuccino frother and start to fill the container underneath.
• the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker.
• after around 30 minutes, when the light comes on, turn the steam knob half a turn clockwise until it stops.
The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows:
• remove the water tank, rinse it and fill it with clean water.
• reposition the tank.
• empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother.
• turn the steam knob half a turn counter-clockwise. Hot water will come out of the milk frother and fill the container underneath.
• when the tank is empty, the indicator light goes off and another light (looks like a pitcher pouring water) comes on.
• turn the steam knob all the way clockwise and fill the water
tank with clean water again.
• the program of descaling is now terminated and the machine is
NOTE: if the descaling procedure is interrupted before completion, the alarm is not deactivated and the procedure
must be started again form the beginning.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE WARRANTY.
You can download the entire pdf manual from the De'Longhi website: http://www.delonghiusa.com/index.php?texts&pid=10&catid=1
Helpful tips:
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water or use abrasive cleaning products/scouring materials on any part of your espresso machine.
Jun 24, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
Sunbeam Cafe EM6910 Logo
424 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
rhodesworks
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
