Question about Lasonic Audio Players & Recorders
Set remote alarm system
How do you set the alarm and the rest of the menu? Does the alarm work like and ordinary alarm clock? Lastly, how do you set the clock? Thanks, I just got it. Literally.
SOURCE: alarm set for certain days
Depress Alarm1 and hold while you then press the alarm mode button until it shows Mon throught Fri. You will then have both Alamrs set for the weekdays but you can set them to different times.
Posted on Dec 29, 2007
SOURCE: smartset cd alarm clock radio-no working alarms
I had this same problem. I removed the battery and then unplugged it for about a half an hour. When I plugged it back in, I had to reset the date, time, year, time zone and alarm times, but the alarms now work!!
Posted on Nov 18, 2008
SOURCE: clock is not working stuck at 12:00 does not
Try unplugging the unit for 10 mins. Plug it back in and hold the CD in Button till it read "RESET"
Posted on Jun 02, 2009
  • 814 Answers
SOURCE: Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Posted on Jun 13, 2009
SOURCE: Jensen jims 225 setting clock and alarm manually
Call Spectra at 800-777-5331, the new remote is $5.00 $3.00 Shiping
Posted on Sep 13, 2010
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Jul 22, 2014 | Bose Wave Radio
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
I can't set the alarm on a Bush dabcr2004/a radio alarm clock
If anyone still has one of these, and is struggling to set the alarm, try this:
For setting the alarm
Press the menu button. Press right arrow button 5 times until you get 'clock' then press select.
You'll see 'set alarm,' press select button again to say yes.
You'll see a display with all the current settings: Alarm 1, the current alarm time and whether it's set for Daily or Once. Pressing the right arrow now advances the hours, the select button moves you on to the minutes, set these with the arrow buttons too.
Select button now moves you to 'Daily' or 'Once' - again you change this with the arrows. Select button moves you on to choose Radio or buzzer (again, you change this with the left/right arrows and press select for your choice).
All settings are done, you can power off now, or I think pressing menu took me out of settings mode and back to radio display.
Turning the alarm on or off:
Press menu, then right arrow 5 times for 'clock.'
Select this and you'll see 'set alarm' - press right arrow button once and you get 'Alarm On/Off.
Now every time you press select, the bell symbol toggles from visible to invisible, visible being 'on.'
You can now press menu to get out of the settings mode.
Jul 20, 2011 | Audio Players & Recorders
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Jun 15, 2009 | Audiovox Jensen Universal iPod Docking...
How do you change the clock? I lost the manual.
1. If the radio / i-pod is on- turn it off.
2. Hit the 'mode' button until the time flashes (it should be 3 times).
3. Use the Tun +/- button to change the hour.
4. Use the Volume +/- to change the minutes.
5. Click through the rest of the options to change between setting the alarm, how to be woken up (chime, ipod, etc), 12/24 hour format, year, and date.
Apr 12, 2009 | Audiovox JENSEN JIMS-190-BK UNIVERSAL...
My ipaq hp pda Rx3115 does not have the right time as my clock does how do i change the time?
Start Menu
--> Settings
--> System
--> "clock & alarms"
There you go. You can even set an alarm. :)
--Eric
Apr 04, 2009 | HP iPAQ RX3115 Pocket PC
How do you set the alarm clock on the Logitech audiostation?
The button on the remote is for the 3D surround mode. This model does not have a built-in alarm clock.
Jan 05, 2009 | Logitech AudioStation High-PerDocking...
Alarm set for certain days
Nov 23, 2007 | Emerson Smartset Clock Radio
Top Lasonic Audio Players & Recorders Experts
Jonathon summesfield
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
