Question about Bowflex TreadClimber TC10
H30 error message - Bowflex TreadClimber TC10
LENS ERROR 2 Exilim EX-H30
Try to reset the camera, by removing the battery and memory card for a few seconds. Then reinsert both and switch on again. Make sure nothing is obstructing the free way of the lens. When it does not help, perhaps a sensor or the movement mechanise is damaged. These errors also occur, when you accidentally touch the lens when it must move out. Before you give a camera to a repair centre, ask what it will cost and compare the price to what a new camera will cost.
Feb 07, 2015 | EXILIM Cameras
Free download handy cam driver
Drivers
click the link, go to option 3 and type in camileo h30 camcorder
Jul 24, 2013 | Toshiba Camileo H30 Hard Drive Camcorder
Can you connect an iPod to this system?
just ipod audio ouput connect auxilary input of system jvc fs-h30 system
May 17, 2012 | JVC FS-H30 CD Shelf System
Casio Exilim EX-H30 Manual to download not found on web site
Try Casio's web site at
http://support.casio.com/manualfile.php?rgn=1&cid=001020152
if you're in North America or
http://support.casio.com/manualfile.php?rgn=1&cid=001020151
for the rest of the world.
Jun 15, 2011 | Casio EXILIM EX-H30 Digital Camera
Toshiba Camileo H30 only records onto built in memory. When I put in an SD card, gives an error message (a yellow exclamation point inside a folder). Please help. The camera is brand new. Regards, AL
The first suggestion would be to check if the SD card is the correct one, and if it is correctly installed. On my Hi-Def Hard Drive Camcorder, when properly installed, the SD card looks like it's "up-side-down" - with the little metal sensors upward. It is easy to accidentally put it in - what seems to me is "right-side-up". Then I see an error message and need to flip it over.
You might also check to see if the metal sensors on the SD card are all intact. Sometimes one of the little metal sensors are slightly out of line or maybe bent.
May 15, 2011 | Toshiba Camileo H30 Hard Drive Camcorder
Replaced bulb but still getting "lamp will fail soon replace" warning
When you replace the lamp, you need to reset the lamp counter as well. The procedure for this should be in the owner's manual. This counter is a guide only. Lamps have an expected lifetime and the message indicates that the lamp is nearing that lifetime. Once reset, the counter will again trigger the message once this new lamp reaches that usage time.
Dan
May 06, 2010 | Optoma H30 Multimedia Projector
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Overheating
i had this problem and the temperature sensor had to be changed....fine after that.....not cheap out of warranty i suspect.
May 22, 2008 | Optoma H30 Multimedia Projector
H30 Crashing
The only thing I can think would be that the projector is heating up because the air filters are clogged.
Jul 09, 2007 | Optoma H30 Multimedia Projector
Bowflex TreadClimber TC10 Logo
21 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
