Question about KDS 2013 New Model Kds8889 Sub. Jbk M5000 Midi Dvd Cdg Cdg Multi Karaoke
Need face plate
Player was dropped broken face plate around screws. Need new part I am a expert sir.
Where is the belt housed on the Hoover vacum cleaner model U5461-900? The belt number is 38528-033 but I can't find where the broken belt is to replace it.
Simply lay the machine down with the brush assembly facing upwards, and remove the four screws holding the bottom plate in place, and remove it. Put the new belt around the motor shaft, then around the brush assembly and push the brush back into place. Turn the brush with your fingers before replacing the bottom plate, to be sure the belt isn't caught between the brush and housing.
Jul 27, 2011 | Vacuums
CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
May 05, 2010 | Pioneer CDJ-1000 CD Player
2003 GMC sierra side view mirror glass replacement
That dependso on if the housing itself is broken then yes. If the face plate that is attached to the mirror itself is flapping around then maybe. If it is just the mirror, just go to your neighborhood auto glass shop and but a "Ready-Cut" mirror for a small amount of money. they come already cut to fit perfectly. As for removing the old glass, take a very small flat screw driver and pry the glass away from the face plate. Once completely cleaned out use the adhesive from the ready cut and place them on the face plate. Next press the new mirror onto the flace pate, being careful not to press to hard or it will snap it in half.
Jun 03, 2009 | 2003 GMC Sierra 1500
A dvd is stuck in my Chrysler town and country multi disk dvd/ cd player. How do I remove it?
Look around the face plate for a very small hole...use a straightened paperclip or equivalent and press in a few inches...its a manuel door release and you should gain access to at least the loading tray.
Apr 24, 2009 | 2005 Chrysler Town & Country
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Faceplate DEH-P5500MP
dude im real good at this stuff and if u dropped it once ur lucky it still worked but if it dont work now ur definitely going to need a new one...
Jan 09, 2008 | Pioneer DEH-P5500MP CD Player
Broken
face is damage u will need a new face plate i had the same problem. i have a working face plate for it $160
Dec 03, 2007 | JVC KD-AVX1 Car DVD Player
My Face Plate was stolen and the Raido isn't 6 Months old
It is available from Pioneer Electronics, but the price will prolly make you pass out.
Check it here;
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Best of Luck.
Oct 25, 2007 | Pioneer DEH-P7700MP CD Player
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
KDS 2013 New Model Kds8889 Sub. Jbk M5000 Midi Dvd Cdg Cdg Multi Karaoke Logo
49 people viewed this question
Top KDS Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a KDS Audio Player and Recorder Expert? Answer questions, earn points and help others
