Question about Sole Fitness F63 Treadmill
Sw ver 11 error
This error appears and it will not let me do anything
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Ms-6541 ver 2.1 mobo pin connector
Hello this should be the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97106&prodTypeId=12454&prodSeriesId=96284&swLang=13&taskId=135&swEnvOID=1093
The front panel looks like this:
d450e023-b94a-4bba-87c8-871096a37704.gifF_P1 PinOut
17 15 13 11 9 7 5 3 1
18 16 null 12 10 8 6 4 2
SHORT:
HDD led op 1/3
Power led op 2/4
Power Sw op 6/8
Reset Sw op 5/7
Here is also the manual:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&locale=en_US&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316609
The usb connector looks like this:
e3c82873-b0a1-49b3-91f4-548ca5550428.jpgIts basicly just to insert the black connector in it.
Best of luck
Jul 16, 2013 | Computers & Internet
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
X 700 scurty code
*#8999*8378# = All in one Code
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
*#8999*8376263# = HW ver, SW ver and Build Date
Feb 27, 2011 | Samsung SGH-X700 Cellular Phone
My Garmin nuvi 710 Can Not find satelitte are software Update. I am using software ver. 4.90, Audio ver 2.3, GPS SW ver 3.00s and Bluetooth SW ver 2.80
If you change location it can sometime take a minute or so to lock onto satellite.
make sure you have clear view of sky and no high buildings.
Give it time to find itself and dont move it whilst doing this.
if this does not work then it will have to go in for repair.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Garmin GPS
Failing to initialise d3d when trying to play tekken 3 game
if problem with d3d
then you need install a other version of windows
because your game need newer version of d3d
i think you are using windows xp which have a direct x ver. 9
so you need directx ver. 10 or 11
you have two chices
you may go for windows vista which have directx ver. 10
or for windows 7 which has directx ver. 11
i thinck you understant
Jan 29, 2011 | Computers & Internet
Me presenta mecha error 12 que sera por favor ayuda gracias
mecha error 11 o 12 significa k algo pasa con la cuchilla, debes de desarmar la impresora y ver si hay algo que la este trabando
Jul 09, 2010 | Kodak 6800 Thermal Photo Printer
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Sole Fitness F63 Treadmill Logo
15 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
