Question about IOGear USB 3.0 Secure Digital/microSD Card Reader
My micro sd card reader is unallocated
Disk Management says unallocated
    Sergeant:
  • 233 Answers
Unallocated means the SD card has either
a. Never been formatted (highly unlikely)
b. Corrupted and lost it's format.
You can format it again with the default settings.
Wiki link guide for PC or Mac here >> How to Format an SD Card
Fat32 is a good choice for Phones, PC data and images.
Posted on Mar 28, 2014
Hi im jr i have aproblem with my 16gb usb drive. in disk management usb drive is unallocated, i do some suggestion in dos using diskpart and when i in clean part prompted "DiskPart encountered an erro
Right click on the drive in disk management(click right on top of the bar graph that says "Unallocated" and then select new simple volume. You should be able to see it under "My Computer" now
Nov 29, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cant reformat my microsd memory card. how can i solve this? please help me
insert your micro sd card drive
click start right click on my computer open you should see your micro sd card
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your sd card select format
hope this helps
Feb 24, 2011 | Computers & Internet
My SanDisk 12 card reader will not read microSD HD in the adapter provided. I went to another adapter and I had the same failure to read. Is there a diver to fix this?
If you by chance reformatted your 2GB micro SD card, then you probably erased the ID letter that Windows uses to mount your card. That can be fixed by going to "Disk management" and using "Change Drive Letter" you can assign another drive letter to that memory card and then windows will see it. You can find the path by clicking on "Help" and asking for Disk management.
Feb 04, 2011 | SanDisk 2GB microSD Memory Card
Sd card is detected but cant open
I find that the easiest place to find files on a HDD or SD card that i connect but the drive comes up is by going right click on computer and going to the manage option.
I then go down to disk management and look for the storage that I have added.
Then right click on "change drive letter and path" and add give the storage a drive letter
For some reason the computer sometimes does not complete this part which leaves the drive unreadable
It is always a good thing to do to go to device drivers to check that you can see the drivers for the device being installed. This can be achieved by removing and replacing the storage device while device manager is open
May 26, 2010 | SanDisk 2GB microSD Memory Card
Micro sd 2gb card, not read.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
Micro sd memory card
Do you have a card reader on your pc? plug it in, open my computer, do you see the card there? if no.
Right click my computer icon on desktop or in start menu, select manage, on the left side select disk management, find the storage card from the drive list, right click create partition or Format, I would go with fat32 format to be sure. then you should see it on the computer asuming if you see the card in disk management but not in my computer. if you don't see the card in disk management and this is a new card. something is wrong, possibly the card reader is broken or there is another issue with your pc, or possibly your sansa has a faulty card slot which has caused the issue. It should work plug and play basicly.
Oct 20, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk (MultiUse) Standard SD Card 2G Partition: 2 Unallocated
Copy all your data, Use SD format tool to restore and then start all over https://kb.sandisk.com/app/answers/detail/a_id/14827/~/using-sd-formatter-tool-to-restore-full-capacity-on-sdhc%2Fsdxc-cards
Mar 25, 2017 | Electronics - Others
Lost Memory Sandisk 6Gb. to 67 Mb.
use the pc to completely format the card, that will or should delete a partition too. format it like you would a floppy disk
Mar 28, 2008 | Cell Phones
Memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
Feb 24, 2008 | Motorola Mobility SLVR L7 Cellular Phone
IOGear USB 3.0 Secure Digital/microSD Card Reader Logo
51 people viewed this question
Top IOGear Electronics - Others Experts
Are you an IOGear Electronics - Other Expert? Answer questions, earn points and help others
