Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell 1800FP no power when plugged in, includes no LED
I had same problem. Changed power cable...nothing. Changed fuse (315mh-250v), reassembled and I am now looking at it!
Posted on Sep 12, 2009
Oops..meant 315mA-250v) fuse
    Genius:
  • Dell Master
  • 1,252 Answers
Change the power cable then check, if the problem persists take it to the service technician the fault may be in the power supply
Posted on Jun 14, 2009
May lcd monitor dell not power
If there is no power or "Led" indicator on the power button, try plugging the power cable to a different power point. If still won't turn-on, try changing the power cable. If still no power. It only means the LCD is already deffective.
Hope this helps.
Mar 28, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I get no power - no LED lights up - does that mean a bad power supply?? I saw a message board with all kinds of comments but all from 2005
Yeah it seems that there is not power. Try plugging the monitor to a different power source and check whether it works. If not then it could be the power supply of the monitor which is faulty.
Nov 03, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800fp
Find and replace the ICE2AS01 on your power supply
Apr 28, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Led flashing no picture
disconnect the signal cable from the computer. if it shows color bars, it means your monitor is ok and your video card is faulty. if it still does the same thing. you need to reseat the video card if its not integrated.
hope this helps.
Apr 09, 2009 | Dell 1800FP Monitor
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computer monitor
try making sure that the power wire has a good clean connection and is securley plugged into your outlet. also try using a different cable like the power cable to your pc. if it still isnt turning on. you will need to take it to a repair shop or replace it.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell moniter
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
646 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
