Question about Frigidaire Gallery GLHS36EJSB Stainless Steel Side by Side Refrigerator
Freezer makes a weird noise
My freezer/fridge makes a weird noise like 2 times a day and the freezer and fridge will warm up to like 20-30 degrees above there normal temp and i dont know why its doing it
its kinda a clicking/buzzing noise
catriver
  • 878 Answers
SOURCE: Fridge and Freezer working intermittently; not getting cold and making a vibrating sound
Dave, what you are hearing is the overload kicking out on the compressor. It's one of two things, either the compressor is failing or PTC (overload, relay) is going bad. I haven't seen too many PTC's fail on Frigidaire, but I have seen a lot of compressors failing. Your refrigerator will have a 5 year warranty, parts and labor if the compressor is at fault. You would have to do some tests on the compressor to determine which one is at fault. If you have a clamp on ammeter you can see how many amps the compressor is drawing during start and run. The compressor should have a label on it with the amperage information. You could just replace the PTC, part number 218721119 and see if the problem goes away but you could be throwing away money here if the compressor is the problem. With out being there, my guess would be the compressor itself. Catriver...post back.
Posted on Dec 09, 2006
Krazytech
  • 725 Answers
SOURCE: Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Posted on Aug 10, 2008
rpbuice
  • 161 Answers
SOURCE: ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Posted on Dec 16, 2008
SOURCE: my light works but the motor won't kick on, Frigidair top freezer
THE CURCUIT BOARD IS NOT SENDING A SIGNAL TO YOUR MOTOR WHICH ENABLES YOUR MOTOR TO KEEP THE VALUBLE CONTENTS IN YOUR FRIDGE COLD...(BEER) EVERY MANS FAVOURITE HOBBY...CHECK YOUR CIRCUIT BOARD FOR CORROSION OR DAMAGE...HOPE THIS HELPS...IF SO SEND ME A COLD ONE
Posted on Dec 20, 2008
carldc3
  • 82 Answers
SOURCE: fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Posted on Jan 05, 2009
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Only one temperature control??
Good day,
Yes, they are made. The temperature in the fresh compartment will be no issue, since you have control in that compartment.
The engineers designed the balance between the two compartments so the freezer would be normal if the following conditions applied.
1. The room temperature is between 70 and 90 degrees.
2. The machine has normal usage. I.E. 8 to 20 door openings of the fresh food door.
The freezer would start getting warmer if the room temperature dropped much below 70 degrees. or..
If the machine had extremely light usage with very few
door openings, or a combination of both situations described above.
With dual controls, and both set at normal, the above conditions would occur anyway, except you could over ride the normal settings to compensate.
Many people have this setup, and experience little trouble, but without knowing your life style replacing it would be your choice based on the facts given.
Thanks for using FixYa
Dec 23, 2009 | Refrigerators
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Whirlpool ER8AHMXRQ01 fridge too cold
Adjust the setting until you can maintain a temp of 0 in the freezer and between 32 and 38 in the ref. These are the normal operating temps for this box.
Apr 02, 2009 | Whirlpool Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Frigidaire Gallery GLHS36EJSB Stainless Steel  Side by Side Refrigerator Logo
32 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
