Question about Oreck Vacuums
Heighth adjustment how do i adjust the highth to vacum
  • Oreck Master
  • 932 Answers
Orecks do not have any height adjustments. If you have high pile carpet and an older model Oreck, you can purchase a high pile attachment and install that on your Oreck.
Posted on May 16, 2015
Height adjustment doesn't adjust work. Vacum Too difficult to push.
Are you Missing the Front Wheels under the Vacuum? This asswmbly can fall off
May 25, 2016 | Hoover Tempo Widepath Upright Vacuum -...
ComThe vacume handle is very difficult to get out of the upright position. It use to take just a gentle tap on the front of the vacume to release the handle. Now I have to stomp on the vacume front to get...
Sorry to hear you're having difficulties with your DC14. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
Belt keeps breaking after only short use on vacum cleaner
Each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn. The belt must be installed according to manufacturer directions for best performance, or the belt will chafe against the interior housing parts and break prematurely.Sharp debris, a low height adjustment setting or vacuuming up rug corners may cause the rubber belt to snap or wear prematurely. Check the height adjustment for the vacuum, and use a higher setting for plush rugs. Avoid vacuuming sharp objects and corners of the rug.
Jul 27, 2011 | Vacuums
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
We have two of these vacuums and both of them have experienced the same problems. First the floor heighth adjustment doesn't work and now neither one will pick up on either carpet or floor when in the...
Did you check the powerhead for obstructions? With a bend in the tube just below where the hose connects, this is a common spot for clogs. To check, detach hose and drop a coin in the hole. If it doesn't drop through, a blockage is present. Use the handle of a wooden spoon to push clog back through to brush. It can be removed with long-nose pliers from there.
For height adjustment, check for debris that may be preventing the nozzle from raising and lowering. There may be something inside the powerhead preventing it as well.
The manual can be found at the following site. On the left side of the page, under the image, click on the Use and Care Manual button.
http://www.abt.com/product/20743/Electrolux-EL5035A.html
Jan 21, 2011 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Axle bracket problem
You can find parts HERE. I do not think you need new "Ratchet Lock Assm." unles yu lost it (I have never seen one broken). Make sure you have the Spring and lubricate it well (do not use liquid lubricants as they will leak on the carpet).
God Luck
Mar 01, 2009 | Kirby G6 Bagged Upright Vacuum
Brush on vacum wont make contact with rug, no pick up
if you take off the brush then reorientate the ends of the brush this will adjust height ends have a block depending on orientation they will set brush height This is common for many brush assemblies and should work for dirt devil
Jan 16, 2009 | Dirt Devil Vacuums
My kirby g6 shimmy's when pushing it
In the shop I would have a whole bunch of questions, so let me try to run a couple of solutions for you.
The things I initially check for are the roller brush adjustment and how high are you when vacuuming.
On the G6 there are 3 adjustments on the end caps 1,2, and 3. There is also a fourth position but doesn't have a number and don't recommend using this position. If it correctly adjusted these things last forever unless you own a golf course, restaurant, or childs day care. With a G6 if you vacuum every day I would imagine you should be on a 2 if you vacuum a couple of times a week a 1 or 2. The easiest way to tell is to take the floor nozzle off, flip it over and look at the end caps should be different color grays dark and light. You should at this point be able to tell the adjustment by the number facing you. If it is on the number 3 setting and you still have quite a bit of bristle move it to the number 2 setting put it back together and try it out. Roller brush adjustment can also be the culpret for many other things especially if your not adjusting the machine to correct hieght while vacuuming (see below).
If you have a really high pile carpet and your going all the way down this can cause the shimmy especially with a mis adjusted roller brush. When you turn the machine on with the heighth adjuster all the way up. Lower the machine one click at a time, until you here a tone change. It will go from a higher pitcher to a lower pitch as the roller brush begins to sweep the carpet. You can click one click past this but really don't want to go anything further it actually cuts down on the suction, and runs through belts quicker.
If you purchased the machine new at your home from the sales guy and in the pitch he talked about the piggy bank slot in the back if you have kids then perhaps your little one made a deposit into the slot. Either way it could be a coin stuck in the gears. It could also be that the gears themselves are slipping.
It could also be inside the transmission a peblle or large piece of dirt in the gears on the inside.
It could be the bearings in the rear axle assembly. It could be the slide assembly would definitely have to look at it to be for sure.
If your handy I could try to walk you through taking the machine apart and checking the the transmission yourself.
It the roller brush adjustment or vacuuming to at the correct height doesn't solve the problem you should probably have a tech look at it.
Aug 23, 2008 | Kirby Vacuums
Vacuums Logo
117 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
