Question about iLive It082b 2.1-channel Stereo Sound Bar Speaker -used
How do you adjust the brightness of the clock ?
The clock display is dim. how do you adjust the brightness ?
SHARP ALARM CLOCK HAS DIM DISPLAY
Some clocks have a display brightness adjustment.
Jun 25, 2017 | Home
Adjusting clock brightness on electric range.
Very few ranges have any type of display dimming. Dacor is the only one I know of. If the display is very dim and hard to read, you will need to replace the clock or Electronic Oven Control. If the range is still under warranty, call Whirlpool and request service.
Apr 08, 2014 | Whirlpool Kitchen Ranges
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Digital clock display read out is EXTREMELY dim even after adjusting brightness and contrast controls
Hello Jinx55,
the problem is the display unit itself or the cable that goes from the display to the electronic (Most likely the dispaly itself).
The display will need to be replaced. You can contact Miele directly at
(800) 843-7231
May 19, 2009 | Miele Coffee System
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Clock radio display doesn't light up.
I just got a similar model at Big Lots a few months ago. A T439S. There some funky stuff they do with those displays it could be that the lamp is wearing out. 7 years is good life for them.
Sep 03, 2008 | Timex T110TT Clock Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
iLive It082b 2.1-channel Stereo Sound Bar Speaker -used Logo
56 people viewed this question
Top iLive Televison & Video Experts
Electro Med Services...
Are you an iLive Televison and Video Expert? Answer questions, earn points and help others
