Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Motor on 856 international tractor locked up
Tractor died while coming down road and the motor is locked up
Farmall 856 hitch does not raise in zero weather
ck to see what hydraulic oil your using , I bet it's an all weather rated oil, if temp is below zero then that's out of "all weather" range , you will need to look into using a cold weather rated oil (ck with you local dealer to ask ), my tractor has an oil bypass lever you can engage on the valve block this allows oil to circulate around in loop to heat up (+20 degrees) to work in cold temps , I don't think a 856 has one of them
Jan 21, 2016 | Farmall IH Tractor 706, 756, 806, 856,...
Johndeere 5525 n tractor locks up driving down the road
We got the same problem with Ford 4-wheel tractors. Slow down. The gears was comes together at high speeds.
Jun 24, 2014 | Garden
Where is transmission filter located on international 756
I t is behind teardrop shaped cover below r ight hand brake drum.
May 20, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
16 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
