Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
I HAVE A BISSELL 12AMPS PROHEAT2X RUG SHAMPOO, IT WON'T PUMP OUT WATER TO CLEAN ,THE BRUSHES WORK BUT NOT ANY LIQUID. ALSO CAN YOU GIVE ME A REPAIR SERVICE NEAR THE 34219 ZIP CODE
  • 365 Answers
You have to stop leaving the cleaning solution the tank after you're done...unfortunately you may be outaluck...try putting a tiny amount of ammonia in the tank and keep pulling the solution "trigger"...maybe you'll get lucky...otherwise trash the vac :o( Sorry
Posted on Jun 14, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat2x carpet shampooer does not dispense water when you squeeze the trigger
this can be one of 4 things the belt on the pump as waren (it may not seam ware but replace it if you can ) the water jets by the roller are bloked ( x2 red ) the pump as faled or this on about 2 in 10 the heter is bloged this hapens then the sope or shampoo is leaft in the heater (the heater bakes the sampoo if it leaft in there with no water flow ) then you have not run clean water frow
Jul 12, 2009 | Vacuums
Where to put shampoo
how do i put in the water and shampoo...???
May 06, 2009 | Bissell 1699 ProHeat Clear View Upright...
Wont release liquid or shampoo.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=601973
Won’t release liquid or shampoo.
Posted by lilmrsmcd on May 16, 2008
I have a Bissell Pro Head 2X Steam Cleaner Model # 9300-C
The little plug at the bottom of the bad for clean water came apart and would not let water out now won’t hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAP liquid bladder will not release water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. On the little black plug – they do wear out and need to replace it but use a genuine Bissell part when replacing the part other wise a replacement may not work. Q. #2 the little propeller spring usually is part of the solution tank and it is wise to replace the part with a new or a good used tank from Bissell, so check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I work this dam thing?????
How do I work this?
Bissell 1699 ProHeat Clear View Upright Steamer
The Bissell has a holding tank to the solution and the recovery tank for the water and soap you pick up -- -both are removable for cleaning purposes – there is a trigger assm on the handle to release the Bissell Soap or detergent that you are using – (low sudsing) and there should be a switch on the bottom of the unit to activate the revolving brushes. So the best way to shampoo the rug is to do it on the back pull – when you pull back you are dispensing the water solution and shampoo by squeezing the trigger assm, the brushes are agitating the carpet and the vacuum part is picking up the water. This is about as simple as I can get it – please refer to the owners manual for the trouble shooting part of the manual or check with your local vacuum cleaner dealer in your area and in the yellow pages under vacuums, or call the Bissell factory phone # or use the website.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac man
Apr 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
178 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
