Question about Baby Gear
Graco swyngomatic manual springing is overwound/18-709
How do you fix an overwound music box?
The spring hub ratchet has to be released while firmly holding the spring hub. Once free the spring pressure must be released slowly. It shouldn't be necessary to release all the spring pressure.
If the spring hub is not held firmly it will fully unwind violently, often breaking the spring.
Jan 06, 2018 | Audio Players & Recorders
Troubleshoot for my new england clock mantel,wind-up pendelum clock?
Your spring may have been overwound. There are several YouTube videos that show you how to release an over-tightened main spring.
Nov 28, 2017 | Home
I overwound my old travel alarm clock. Is there anyway to fix this on my own? I'm pretty handy with jewelers tools...
to unwind the clock, you need to open the winding spring.
Open the back, and there should be a part to move and unwind it.
Be careful to put the pieces in reverse order when you take it apart, so it will go together correctly I only say this because I've had to fix sewing machines that were not put together correctly..
Apr 10, 2013 | Audio Players & Recorders
How to fix an overwound clock
first thing you will need a new spring
Dec 02, 2012 | Audio Players & Recorders
There a bar that came off the swing that I have. Just using for the first time it was given to me by some one so it does not have instructions. So can u pleaseeeeeeee help me and tell me where the bar is...
Most of the time if you go to Graco's website they have manuals for these type of items. I had to do it for my new Fisherprice swing. If you can not find it there call them and they will send you one. I had to do that before too.
Jul 08, 2011 | Graco Winnie the Pooh Swyngomatic Infant...
Can't open graco stroller
  • press the 2 red buttons
  • kick the spring
  • pull the seat out
  • press the look on top
  • push the seat out
  • aim only 10 years old i bought the graco stroller for my 2 dolls it a real stroller
May 01, 2010 | Graco Alano Travel System 7F08DSW3...
Pocket watch seems overwound
INFO:
If you wound the watch and it ran you would not say you over-wound it.
The only way it is over-wound is if you wound it so Hard you broke the spring or broke off the stem.
The fact is your watch has Stopped running.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 09, 2010 | Watches
Quick release spring on rear hub is missing on Graco stroller.
hi mkzwood! check this link below. you need to provide graco some details so they can find the replacement part for you. surely they have available quick release spring. hope this helps! please let me know the outcome. thanks for using fixya
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
Jul 04, 2009 | Graco Baby Gear
Instruction manual for Graco - Sarah 4-in-1 Convertible Crib, Che
My wife and I bought this same crib. We thought the same as well. We looked everywhere for the instructions- so we thought. We finally found someone to call and ask for help and she told us to
" Look in the box that has the mattress springs in them. The instructions are normally attached to them."
As I was on the phone with the lady helping us, I opened the spring box and there they were attached to it inside a white envelope.
Jan 08, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
Graco lauren crib conversion instructions
I have posted the instructions in an album on photobucket. I believe you can print them from there. To get to them, go to photobucket.com and in the website only search field (not the web search) type emilykenepp and change the search from images to people. It should bring up my profile and under albums I have an album called Graco Lauren Crib Assembly Instructions. Click on that and you're good to go! Pages 10 and 11 are for conversions. If you have any further need, the number for LaJobi is 1-888-266-2848 and the number for Graco is 1-800-345-4109.
Jan 04, 2009 | Graco Lauren Crib
Baby Gear Logo
82 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
