Question about Lenovo Computers & Internet
Broken battery latch
I turned my laptop over and the battery latch fell off. How can I fix this?
How do I fix a broken battery latch on my HP EliteBook laptop the battery keeps sliding out
Try description on ebay. Maybe a complete base will be required to take the latch from?
Dec 01, 2014 | HEWLETT-PACKARD HP EliteBook Notebook
Broken door latches
remove the door card inside .fix it from there.
Apr 16, 2013 | 1995 Jeep Grand Cherokee
I have a gateway nv79 and it won't turn on. The
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 10, 2013 | Computers & Internet
My laptop accidently fell off my coffee table on unto the carpet. I noticed some of the keys popped out. Can this be fixed???
Yes, this can be fixed as long as the key latches are not broken. If the keys just came out then they can be put back but it is a very time consuming and frustrating job if you do not have a lot of practice doing this. Your two options are you can try to follow this video and do it yourself or you could take it to a repair shop and they can replace these keys for minimal cost and time on your part.
Good Luck.
Apr 29, 2011 | Apple MacBook Pro Laptop Computer with...
HP Pavilion dv5003cl won't turn on after small fan falls on it.
If the fan fell directly on top of it then it could have destroyed your lcd display. Power down the laptop completely, plug external monitor into vga port on laptop, power on laptop. If you have video on the monitor then you would likely need to replace the screen. If you send it in to get fixed it will cost a lot of money. You could do it yourself if you are comfortable with that type of thing.
Sep 15, 2009 | HP Computers & Internet
Loose parts
If your battery is loose, it could be either the battery's latches are defective/broken... a new battery would fix that. Or the hook/latch mechanism on the laptop itself is defective and will not latch onto the battery, a replacement laptop case would probably fix that one. Good luck.
Jun 11, 2009 | Dell Inspiron 700M Notebook
I need to know WHERE to get a battery latch.
call Nikon parts replacement for a new latch, It's easy to install
Nikon Parts Department
7AM - 3PM (Pacific)
Monday - Friday
310-414-8107
Fax- 310-322-6979
Mar 07, 2009 | Nikon Coolpix S210 Digital Camera
Dell inspirion 5100 fell
Before you can think of fixing it, ask yourself what is there to fix.
open your laptop check for any broken parts on the board if its fine which i highly doubt also check whether any broken piece got into the fun. And for the monitor connect an external monitor and see what happens.
Jun 19, 2008 | Dell Inspiron 5100 Notebook
Computers & Internet Logo
11 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
