Question about Lowrance Mark-5x
I want to replace my older x 71 with a mark 5x. do i need to replace wiring and transducer or are they compatable
Does x71 and mark 5x use same wiring and transducer
Why won't it turn on?
get a can of contact cleaner and disconnect all wiring one at a time and spray them down as you go along . stuff on boats do not like corrosion of any kind .
Aug 05, 2015 | Lowrance Mark 5x Pro Fishfinder
What's wrong? My Lowrance Mark 5x dsi depth finder flashes or pulsates a depth of 60 ft. All the time.
Since the unit powers up, we can pretty much eliminate a power supply problem.
I would start by carefully inspecting your transducer lead for kinks, crushing etc. Assuming the cable is OK, clean and lubricate (silicone spray, safe for plastics) the cable end and where the cable connects to the unit.
Hope this is helpful to you.
-Steve
May 04, 2015 | Lowrance Boating
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
How do i use a lowrance mark 5x fishfinder to operate mark 5x fishfinder for finding fish and navagation
Mark 5X is sonar only no GPS, so navigation is out.I would suggest you start by running the unit with factory presets to get started as you get used to using it. There some great training videos on YouTube for beginning to understand how to read your new sonar system.
Sep 14, 2014 | Boating
My asus x71 s does not read it's hard drive
Remove HDD, test, replace if necessary.
Jan 09, 2013 | ASUS Computers & Internet
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
My Lowrance X-51 is not reading the depth sitting still of running . Do I need a new transducer ?
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Jul 31, 2009 | Lowrance Boating
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
Lowrance Mark-5x Logo
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
