Question about Troy Bilt Tb70ss Gas Trimmer
Gets fire, gets gas, won't run. Spring assisted
Gets fire, gets gas, won't run. Spring assisted cranking.
Pull cord hung -up before this happened, but works now.
HELP!
  • 1,041 Answers
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 17, 2009
  • Jim Parker
    Jim Parker Jun 17, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Pull cord works; but does not engage the crank
when you pull the cord the motion pulls out 2 pins that ingage the clutch. Some times when to much oil , dirt and wood dust gets in there it sticks. Some times I just clean it and the spring out and sometimes they are worn out
Jun 05, 2014 | Stihl 015 Chainsaw Starter Pully
Model 944.361200.mower won,t start in colder weather,once temp gets above the70degree mark it will start,but blue smoke comes form exaust.mower will start right away every time once engine is hot.fresh gas...
I have a mower with a Honda 165cc engine that is temperamental as far as the initial start up is concerned.
Once it has started it always fires up first pull
The problem seems to be the gas is slow to reach the carb / cylinder
I have developed a ritual for starting up.
Open the gas tap.
Lean the mower back until the hand bar touches the ground.
Raise the mower and lift the hand bar so the back wheels are off the ground for a few seconds.
Fully open the throttle, Hold the ignition control back and operate the pull cord.
If it doesn't start first time I am usually rewarded with a promising fire-up.
Sounds wacky but works for me and used to spend 20 to pulls on the cord to get it to fire .
Oct 24, 2017 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
94 Oldsmobile 88 Royale turns over, gets fire and gas but won't start
Crank position sensor...i have same car and that happened to me
Oct 14, 2012 | 1994 Oldsmobile 88
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
The PB-250 will not start. It was purchased last year and used little. I have fresh gas and a new properly gaped OEM plug. I do have spark. The spark plug is wet with fuel. Can one flood the engine by...
It is very easy to flood this item mind you its easy to flood all petrol trimmers. If plug is wet simply turn the switch to off and pull cord at least 15 times you should get the engine to start coughing keep pull cord but do not turn the petrol on do not prime it either. It should catch. If it does not push the primer once and pull cord
May 31, 2017 | Echo Gas Blower 135 MPH390 CFM Blower...
I have a Husky 435 model that is less than 2 years old and as cut only about a cord and a half of lumber . The saw runs fine when it is running the problem is getting it started in the first place . I...
It should start easily, start with fresh fuel/oil, pump the primer as many times as it takes to 3/4 fill the bulb, pull the choke fully out, crank the engine until it fires once, push the choke fully in and crank again until it fires up, after re fueling a warm engine, pump the primer again until it 3/4 fills the bulb,before cranking the engine pull the choke fully out and in again( this will engage the part throttle ) then crank the engine until it fires up.
May 15, 2011 | Garden
I have the ATK125A go kart and it will not go in reverse and is in 3rd gear and will not come out of 3rd. What can i do?
I have a atk125a go kart and it won't start... Gets fire and gas.. It will crank over and over but won't run. Had the cdi checked and it was good. No fire to the kill switch.. Please help i'm about to pull my hair out. Please e-mail me at trevorsimper@sbcglobal.net with answers....
Dec 28, 2010 | Sport & Outdoor - Others
Can,t hardley pull starter cord. I've removed muffler and carb. It will pull fine if the spark plug is removed (w/or with carb and or muffler . this is a poulan pro 18"
What i have to occasionally do for a chain saw after it sits all winter is to put something like WD40 in the spark plug hole and crank it over several times. What happens to me is that the piston gets gunked up from the gas that ran down into it during the winter and it won't crank over hardly at all. This is probably your problem. I have also found that if i store my saws with the tank down, the gas cant get into the carb and do this. (Although it's better to drain tank).
If this has been a running saw instead of a stored one, you probably need a rebuild kit if the piston is scored.
Apr 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Troy Bilt Tb70ss Gas Trimmer Logo
156 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
