Question about Asics Gel Kayano 15 Running Shoes for Women
Item not described correct
They were altered and cannot be worn
    Master:
  • 965 Answers
If you got goods not according to order, contact the person or company that sold you them and make arrangements about goods not according to order and if they are honourable, they will take care of this foryou.
Posted on Jun 03, 2016
83 olds car doors,will not close on one side,the other won't open or close
doors do not alter in their openings unless the following has occurred
accident that alters the door opening shape or alters the door hinge position
badly worn hinges
people hanging off open doors or lastly
the sill panels ( rocker panels ) under the door that are part of the door opening and body strength have rusted away under the car allowing the door opening to alter and affect the doors closing properly
Oct 19, 2015 | Cars & Trucks
Tip
How to file for the Significantly not as described dispute - eBay buyers
Here's how to open an Item Significantlt as Described Case:
1. Go to your "My eBay" page.
2. Under "Account" (or "My Account"), select "Resolution Center."
3. Under "I bought an item," select "I received an item that does not match the seller's description."
4. Click "Continue."
5. Enter the item number or select from your recently won items using the "Find Item" button.
If you click "Find Item," you'll get a popup window. Simply select the item, then click "Continue."
6. Click "Continue."
7. In the "Describe the case" page, select the payment method you've used to pay for the item, select the payment date, then click "Continue."
8. Review the tips provided. Click "Continue," if you're sure you want to submit the cas
on Jan 21, 2010 | Computers & Internet
Will driveaxels cause a wobble in the front end?
it is possible that a bent shaft or failed cv joints will cause the problem
it depends if the wobble starts at a certain speed and gets worse up to a speed then stops or just gets to the point where steering control is lost
because the bearings have been replace along with tie rod ends I am tempted to consider that the axles are not the problem ( unless the repairs stated were done to fix the wobble ) but the the wheel bearing adjustment is not correct and that the fittment of the tie rod ends has altered the wheel alignment
consider a wheel alignment to correct a castor fault ( wheel wobble) and recheck the correct adjustment of the wheel bearings
if the cv joints are worn , dry ,they can be binding up and not altering angular movement easily which may appear as a wheel wobble
Oct 10, 2015 | Cars & Trucks
What is the dwell on a 1956 235 6 cylinder
the dwell angle and the point gap are closely related and seldom alter unless the point cam is worn or the point rubbing block is worn To go back to 1956 I will have to open some old manuals to get the dwell so if you make a comment I will see what I can get for you. As you can appreciate the dwell angle is the degrees turned that allows maximum saturation of the coil to produce the hottest spark and that is why I mentioned that the point gap is critical to get the correct dwell.
Jul 26, 2014 | Chevrolet 1500 Cars & Trucks
I need a gas tank for homelite mighty lite 26ss. the whole is too big in the gas tank for the gas line.
No, what you really need is the "correct" sized fuel line. Do not alter the hole in any way. Here is an offering for a complete fuel line replacement "kit". I think it is Amazon.com. The sizes of line they have should fit your make and model. See the third Item listed under BLOWERS at the top of the page. Click on that and you will see the item you actually need. Reasonable price too.
http://www.homeliteblowerparts.net/#2
Aug 29, 2011 | Homelite Mighty Lite Lawn Trimmer
THE COLOR PRINTOUT IS DIFFERENT FROM THE ORIGINAL PICTURE; HOW DO I ADJUST THE COLORS ON THE PRINTER TO MATCH THE ORIGINAL COLOR?
What you described can mean one of two things.
First, that your monitor is not correctly set up for the colors, this is unlikely unless you have altered your display settings.
Second, You are running low on a certain color ink.
Mar 03, 2011 | Canon PIXMA MP780 All-In-One InkJet...
MY DAUGHTER HAS A 1997 JEEP WRANGLER. SHE HAS BEEN EXPERICENCING THE FRONT END SHAKING BADLY WHEN SHE GOES OVER 55. IT WAS SO BAD LAST WEEK I HAD IT TOWED HOME BECUASE WE COULDN'T DRIVE IT OVER 35. A...
What you have is called "death wobble" The most common cause of that is worn ball joints. Other causes can be worn pivot points or bushings anywhere in the front suspension, sometimes not one individual component but the total play caused by several components with some wear.When checking, always inspect the mount bolts on the steering box as well. I have seen some that actually had the chassis tear around the bolts.
Other less frequent causes are: Tires that have "passable" tread but not sufficient to overcome side loading from bumps in the road. Each tire acts as a gyroscope. When not worn, centrifugal force keeps it running true. When worn it can be thrown into a wobble when it hits a bump and flexes.
Improper wheel torque (uneven) can also cause wobble. To correct, relieve tension from all the lugs and use a torque wrench to re-tighten, following a star pattern. Last resort is to have the caster altered past the stock setting in a positive direction. That tends to make the front wheels want to track in a straight line much as why a bicycle can be ridden without holding the handle bars.
The one item that is often blamed for your condition is the steering dampner (sideways shock on the steering linkage) it can be damaged by excessive wobble but rarely will it cause it.
As you can see, there is no one "perfect" answer to your problem but one of the items I mentioned should prove helpful!!!
Nov 26, 2010 | 1995 Jeep Grand Cherokee
Auctions: I purchased an item and is was not exactly as desc...
With regard to this, you will need to file the item not described dispute so that you can get your money back.
Here's how to open an Item Significantly not as Described Case:
8. Review the tips provided. Click "Continue," if you're sure you want to submit the case.
May 16, 2010 | eBay Auctions
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
May 30, 2009 | Computers & Internet
Asics Gel Kayano 15 Running Shoes for Women Logo
Top Asics Clothing Accessories Experts
David Payne
David Payne
Da Doc
Are you an Asics Clothing Accessory Expert? Answer questions, earn points and help others
