Question about Jabra Stone Bluetooth Headset
Will not pair with my cell
Will not pair
Bluetooth cannot pair with other phones samsung S3653
Hi, it may happen if you have more paired list in the Cellphone. Please delete which you have already paired devices. Then try pairing new device. If it is not pairing then check whether you have selected Visibility in the Bluetooth settings.
Mar 30, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I have my first cell phone pair with my Jabra BT2035 headset, how do I pair my second cell phone with this headset?
While you can't actively be connected to 2 phones at one time, you can pair with more than one phone. Just turn off the headset, then hold the call/end button on the headset until the status light stays solid. Initiate search on the 2nd cell or PC/Mac and if prompted enter the 0000 pair key.
Now you can connect to the Jabra from one or the other phone/computer. I used this method for to connect to my blackberry for work and n97 personal phones.
Jan 06, 2011 | Cell Phones
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | LG Dare VX9700 Cell Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Parrot 3200ls bluetooth wont pair with phone
go to SETTING / PAIRED DEVICES / move onto a paired device and press the middle button , then scroll down to delete and press middle button, then press green to confirm.
Apr 08, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Unable to pair with CK3100
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the memory is being cleared. Then she will prompt you to pair your phone.
Feb 05, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Pairing a Motorola H850 to A Lg5300 cell
hi
turn on your hands free device. find "connectivity" in settings on your phone. then "bluetooth link". then "hands-free". turn on bluetooth. look for devices. pair from there.
that should do it.
dave.
Dec 02, 2007 | Nokia 6233 Cellular Phone
Jabra Stone Bluetooth Headset Logo
24 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
