Question about Milwaukee Drills
Light won't go off on my Milwaukee drill
Drains battery
  • Dan Renner
    Dan Renner May 13, 2014
    It seems that no one has a solution for this. My drill is only a week old and started doing this today. I figured if it was a common problem (and it seems to be), someone would have a fix, or at least a response, online. So far, no luck.
  • 2,471 Answers
Take it and your receipt back where you bought it. Ask for a replacement.
Posted on Apr 30, 2018
cesar_quant
  • 74 Answers
SOURCE: i have a milwaukee 18v cordless drill with litium
probably ur battery has memorize the charge u have to discharge completely the battery until there´s no power in it. so u can charge it again.. otherwise..change the batt!
Posted on Mar 10, 2009
comax
  • 154 Answers
SOURCE: milwaukee 18v battery
No, it's showing that the battery is either not taking a full charge or the charger is not charging the battery properly. Find a Milwaukee service center, they will check them and most likely replace one or the other.
Posted on May 28, 2009
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Posted on Dec 15, 2009
  • 144 Answers
SOURCE: How long I have to
Hi payomp,
There should not be any problems with letting it charge as long as you want, as they don't over charge. The charger usually cuts off so no damage is done to the battery. That is what I have found to be the case with most manufacturers. Hope this helps you out a bit. Regards and good luck. Denis.
Posted on Mar 01, 2011
david04928
  • 102 Answers
SOURCE: Milwaukee m18 impact non functional. Light stays
Probably the battery is not good or the charger not working
Posted on May 14, 2014
Milwaukee M18 fuel porta bandsaw will not run. I pull the trigger and get 8 flashes from the led light and thats all. I have tried a very different batteries and the same deal.
drill battery for MILWAUKEE M18 is 100% compatible and will meet or exceeds original specification. This M18 replacement battery made by Amstron has been tested for safety and designed for high performance. Replacement for MILWAUKEE M18 Cordless Drill Battery
Jun 27, 2017 | Milwaukee Drills
Why Does my led light for a Milwaukee 1/2 13mm drill driver stay on, Unless the battery is out.
some have a switch that turns the light on and off . did you look for that ?
Feb 01, 2016 | Milwaukee Drills
How to release battery from Milwaukee drill?
Model really helps, since Milwaukee makes a few different varieties with different battery styles.
and...
I think you owe me $$$. ???
Jun 13, 2015 | Milwaukee Drills
My M18 Drill has an LED Light that does shut off when I let go of trigger.
That's the way the LED is supposed to operate. It comes on when you activate the trigger, and shuts off 10-seconds after you let go. It's a feature listed in the manual. Unfortunately, some of them seem to be staying on permanently, which does drain the battery, and no one seems to have a solution. Obviously, this is a flaw in the electronics governing the LED. Milwaukee should fix them for free.
Nov 18, 2012 | Milwaukee 0822 24 V18 Driver Drill Kit
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
I have 28v milwaukee tool kit and the batteries, both of them, went out at the same time. Strange! Upon charging the light on the charger blinks red and green. The batteries will not charge. Whats up with...
you can try and unplug the charger for a couple minutes and then retry. I have a LiIon at work and sometimes it does it also, if not then the batterys would probably be bad, I would contact Milwaukeetool.com and see about warranty replacement for these. They have a good warranty on the newer products.
Oct 28, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
Milwaukee 18v battery
May 27, 2009 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Drills Logo
179 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
