Question about Nordic Track NordicTrack Commercial 1500 Treadmill
Adjust moter belt nortic track 1500
Adjust motor belt
2 Suggested Answers
mvogt55239
  • 914 Answers
SOURCE: disassembling my 1500 nortic track treadmill
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The following link is to a manual for your model. This should provide some insight before disassembling the unit. The most important part is to label the connection wires so that you are sure where they go when you put it back together. Also be considerate of any pinch points so that you do not accidentally pinch or crimp any wires when putting it back together.
249920 NORDICTRACK 1500 TREADMILL SPORTSMITH net
Posted on Jan 04, 2016
Disassembling my 1500 nortic track treadmill
Jan 04, 2016 | Nordic Track NordicTrack Commercial 1500...
Why wont my nortic track 2100 respond to pushing the buttons
Unplug it completely, and wait a couple of mins, try again, if still no response you may have a main circuit board fault.
Jun 24, 2014 | Nordic Track Nordictrack C2100 Treadmill...
How to adjust belt?
If you are adjusting the walking belt that much (7 complete turns) it sounds like the drive belt the small rubber belt from the motor to the front roller is really loose. You should only have to adjust the walking belt 2-3 turns max... you do not want to prematurely stretch your walking belt!
May 14, 2014 | Nordic Track Exercise & Fitness
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
Track needs to be tightend on my nortic track c 1800s
Step 1:
please see the video and diagram attached. God bless you
Step 2:
mkwrinri3haaaaaelftksuqmcc
Step 3:
h8oly96lhb9tqaaaabjru5erkjggg==
Jan 04, 2013 | Nordic Track NordicTrack C 1800S Treadmill...
Nortic track c2155 will not propel. computer portion turns on fine but when hitting start nothing happens. i hear no motor sounds or anything. however, the track will move if pushed manually.
Unplug the unit and remove the motor shroud insert plug back in the outlet.The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood.If it operates on an open-loop system, the computer will run normally and not give and error code, but the motor will not turn. If you have a multimeter, you can test to make sure you have DC output from the controller spades if not replace the control board. If you have DC output, but motor is not turning the test the motor itself.
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
Lantern battery- a fully charged lantern battery should operate your motor at a slow speed but lacks the amperage to have someone walk on the belt. If it does not rotate replace motor
May 28, 2010 | Exercise & Fitness
I have a Nortic track exp 1000 about 4 to 5 years old. It has recently started to speed up on it's own. It happens only occasional.
Check speed sensor and make sure belt is lubricated. If this two are fine than motor control board may need to be repaired or replaced.
Feb 20, 2010 | NordicTrack Exercise & Fitness
Own a Nortic Track apex 4100i. Great treadmill.
You need to have the power supply board rebuilt with larger Caps and resistors. Look on the internet under treadmill repairs. The board is easy to replace yourself so don't have someone come in and overcharge you. I think about 4 screws and two plugs.
Feb 10, 2010 | NordicTrack E4000 Treadmill
The moter stops when my maytag washer changes cycles
motor is most likeley bad no adjustment on belt i change motor on this make 3 .4 times a week
Feb 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Sharper Image Power Tower 200 won't turn
Most likely the belt is broken. The CD track can be removed by taking a slot screwdriver and gently pushing in the center tabs on any track. With a little patience you will eventually release the track and expose the inside where the motor, gears and belt drive are located.
Dec 20, 2008 | Sharper Image Power Tower Motorized DVD...
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
48 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
