Question about GE Heating & Cooling
Ge TFN60RCP Need A Fues
I have no power to my ignition or my dash and can't find the fues to fix the problem because there no diagram for the fues box
Is this still 2000 mitsu eclipse? Check fusible link 8--30 amp. If not the same vehicle, I need year--make--model?
Apr 22, 2017 | Cars & Trucks
Need wire diagram
prettty straight forward the two lines coming from breaker go to one side of disconnect two wires from conedensor contactor go to the other. the ground goes through disconnect and should be bonded to housing of disconnect.
Aug 04, 2015 | GE 60a Air Conditioner Disconnect Tfn60rcp
Problems associated with copeland sroll compressors in industial ai conditioning systems
There is either a valve sticking in the compressor or the orifice tube or expansion valve is clogged. Time to drain, and flush to check the orifice or exp valve. If not those then replace the compressor,.
Mar 10, 2014 | GE E Industrial System Tfn60rcp 60a Air...
What is the fuse box layout for 1998 nissan pulsar need to change a fuse but layout is all in Japanese dont know which fuse to look for . both front park lights are not working so wanted to check the...
Hi,if you know where the fues box is your half way there.
just buy a electricle screwdriver that has a light inside it with a wire that has got a crockerdile clip on the end,
put the cockerdile clip on a earth the body of the car,
then look at the fues on the top of the fues there is two little bits of metal these are where you will put the screwdriver blade to,
if yoy put the ignition on then go back to the fuesestuch one side of the fues on the little bit of metal the screwdriver should light,This is the power side,now if you tuch the screwdriver on the other bit of metal the light should come on again,if it dose the fues is ok,
if not the fues is falty(replace fues)do this to all the fueses and you will find the fues that is falty.
all the best.
Mar 20, 2011 | Nissan Pulsar Cars & Trucks
Where is the the fuse panel/box so that i can replace the dome light.
FUSE PANEL IS ON DRIVER SIDE UPPER LEFT OF THE BRAKE PEDAL VERY HARD TO GET AT,YOU NEED A FUES PULLER TO REMOVE FUES. DUMB PLACE FOR FUES BOX!!!! I HAD A 93 BLAZER,,GOOD TRUCK LASTED OVER 500,000 KM.
Jan 28, 2010 | 1994 Chevrolet S-10 Blazer
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
