Question about Microwave Ovens
Sharp parts manual for R-320W
Front display panel
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
Display panel r-1514
Possible that the control pad or the main board or the processor is faulty. You can remove the top cover after disconnecting and remove the front panel, check for insects within that have nested , if so clean the board and reset the panel connection. If not you can call for help to Sharp support at your place.
Check website : Sharp
Jan 31, 2013 | Sharp R-1514 Microwave Oven
The front top cover over the face of the R-1611 is broken
The service manuals you'll need to refer to are here and here.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 09, 2013 | Sharp Microwave Ovens
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
I also have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave part works fine otherwise. What part do I...
It is a display panel you require and you should be able to get a manual at the same time.
Try http://www.sharpdirect.co.uk/support/spares-and-accessories/page/spares/
Hope it is helpfull
Feb 27, 2011 | Sharp R-319FW Microwave Oven
MICROWAVE OVEN MODEL R-1405 THE INDICATOR NUMBERS ON FRONT PANEL DO NOT WORK WHAT DO I NEED TO FIX PROBLEM?
A faily common problem. You need a new display panel to fix that. The display panel comes separate from the control board.
Feb 12, 2011 | Sharp R-1405 / R-140 Microwave Oven
Can i get a display screen for a sharp microwave model # R-530ES, and if you can provide this display, can it be shipped to miami?
The relevant service manuals are HTML clipboard here and here. hey contain detailed disassembly instructions.
There are three ways to get this fixed:
1. You could order a new power unit (lower board assembly) and a new upper display board assembly, solder them together, then replace your assembly with the newly assembled one.
You'd need the following parts:
DPWBFC167WRKZ CPU/LSI/display unit $107.07
DPWBFB094MRU0 power unit $53.09
Which can can be ordered from Encompass here.
2. This option is more difficult, but cheaper. You would order the upper circuit board assembly, desolder your old one from the lower power board, then solder the new upper board onto your power board.
You'd only need to order this part:
DPWBFC167WRKZ CPU / LSI / display unit $107.07
3. You could send your control panel assembly for repair for $39.95 with a one-year guarantee. Details are HTML clipboardhere.
Aug 31, 2010 | Sharp R-530ES Microwave Oven
Sharp microwave r610dsa - display faint - barely visible.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have the full service manual at our site, which contains the specific safety & disassembly information you'll need here.
If you decide to send yours in for repair, we would really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the manual.
If you prefer, you can order part number DPWBFC212WRKZ (CPU/display unit) for $73.33 plus shipping from Encompass here or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 08, 2009 | Sharp Microwave Ovens
The time display on my sharp r-425ew microwave went out.
in the particular sharp model u have ,u can replace the display clock.
Dec 29, 2008 | Microwave Ovens
The piece of **** we own is pt# r-1500. In less than a year the lcd display shut down. Now the switch assembly has broken and we have been informed the entire control panel assembly is unavailable. Nice...
Both parts are readily available - you can order them from Martin Microwave Inc.
(toll free 1-877-894-0035).
The lcd / control board / display is Sharp part # CPWBFB075MRU0 and it sells for $79.99
The button assembly is Sharp # JBTN-B122MRF0A and it sells for $13.99
You can also check with www.microwavedisplay.com for a rebuilt board
Sep 10, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
