Question about Samsung RS2630SH Side by Side Refrigerator
Noisy Fridge noising fridge (grinding noise/squealing) Ceases when opening door but starts again upon closing door. Defrosted it a couple of months ago and came good but has started to make the same noise again. Sometimes it's very loud and then stops for a few days and ramps up again. It's level on the floor, there is no error messages showing anywhere. I think it might be a fan belt somewhere something affecting the ice maker housing whereby it ices up and then struggles to cool. However the fridge/freezer is not losing temperature at all and sitting on -15 (freezer) and 2+ (Fridge)
  • Samsung Master
  • 17,455 Answers
Sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Posted on Apr 23, 2017
bobotfel
  • 236 Answers
SOURCE: Noise
Turn of the circuit breaker before doing this or plug out the power cord..
- check if the fan motor is not stuck up by touching the fan blade by your finger if it rotate freely. If stuck up full out the fan motor and put a little oil and rotate it manually until it turns freely.
- Check and rotate the fan blade manually and be sure that it is not mis align and not touching the fan blade frame.
- Check for loose bolts and screws that cause the fan motor vibration.
- Check for foreign object that obstructing the rotation of the fan motor.
- Check for defective bearing or bushing.
Posted on Jan 03, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
woodchuck789
  • 4070 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
heatman101
  • 43501 Answers
SOURCE: Hi, My fridge ( 420 ltrs)
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 14, 2010
hvac1960
  • 2133 Answers
SOURCE: My refrigerator side is not cooling well. I see
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Posted on Jan 29, 2011
Creaking noise after refrigerator door is closed
only thing I can thing of is the slight vacuum caused by the quick temperature change when the warm air that enters when the door is open is trapped after closing the door. As it cools it shrinks and creates a mild vacuum which should dissipate after a few seconds. The creaking is probably the sound of the pressure regulating between the fridge and the room. Might indicate a problem with one of your seals but more than likely is not a concern.
Mar 27, 2014 | LG LFC25760 French Door Refrigerator
Squealing Grinding Noise
Sounds like the interior fan may need to be lubricated or even replaced .
Mar 20, 2014 | Samsung RS2630SH Side by Side Refrigerator
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
RLA Future Hotpoint Fridge
This may be caused by a fanmotor touching something, or one of the copper tubes from the compressor causing a resonant frequency. If you touch the different tubes to find out which one is causing the noise and then slightly bend it with your fingers. That should stop the noise.
Mar 13, 2009 | Hotpoint RLA30 Compact Refrigerator
Fridge fan noise
Du musst den Abtausensor erneuern, ((Gelbes Kabel ))
Jun 03, 2008 | Samsung RS2534 Side by Side Refrigerator
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Samsung RS2630SH Side by Side Refrigerator Logo
64 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
