Question about Kenmore Front Load Washer
Kenmore washer 970 not spinning or agitating.
Kenmore washer model 970-C47062-00. The washer fills and pumps out but the drum will not move. The lid switch seems to check out fine. The timer also cycles through the final spin real quick and just turns machine off like it is finished. The motor and belt seem ok the drum bearing was starting to get a bit noisy but spinning it by hand seems to still be holding together. Thanks Ryan
jsrock516
  • 5911 Answers
SOURCE: Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Posted on Jul 10, 2007
  • 30 Answers
SOURCE: Kenmore Washer No Spin >> Motor problem
Not_a_fixit is correct. If your agitator does not spin, it is the motor coupling. Then again, if your agitator tries to spin, it is the dog agitators.
Posted on Mar 14, 2008
hiltonjug
  • 612 Answers
SOURCE: Kenmore 80 series won't agitate
You will need to check you water level switch. Sound like it is bad or has something clogging it. You can test it like this. Find the tube that runs from the back of the level switch down to the outer tub. Unplug it from the tub. Now turn machine on so that it will start to fill. Now blow pressure into the tube. If it does not cut the water off, you have a bad switch. I would think it's bad. I see them about 5 ir 6 times a week.
Please rate solution if helpful.
Posted on Aug 25, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Aug 27, 2009
  • 1937 Answers
SOURCE: Kenmore 70 Series Washer (mod# 110.20722990)
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.20722990) and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: Ranging from relatively easy to messy (draining oil)
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It's also possible that the Neutral Drain Assembly in the transmission is broken:
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Ours had a similar problem.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
All of the above sound more difficult than they really are. If you're comfortable with a socket set, pliers/vice grips and willing to get a bit dirty (oil) you can save some considerable money.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on May 26, 2010
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Kenmore Elite Model 11023032101 will not Spin
if it agitates and pumps out water it is not the lid switch.  you most probably have a bad brake/clutch mechanism.  the fact that it spins tells me the transmission is good
Jul 30, 2010 | Kenmore 23822 Top Load Washer
Kenmore washing machine fills and pumps out but does not agitate or spin. The model is a 970-C29052-00 Serial #XL94933842. Thanks, Tim
Hi Tim and welcome to FixYa. I am Kelly.
I will be replying 2 times here but wanted to send this first one now so you can possibly check the lid switch. The machine will fill and pump out but if the lid switch is not functioning it will not agitate or spin.
As you just open or close the door or lid you should hear an audible click from the micro-switch. If you do not hear that click, The lid switch has a problem. (loose or failed)
The model number does not cross:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=970-C29052-00&=part+number&pathTaken=partSearch
Search results: "970-C29052-00" We're sorry. No exact or partial matches were found.
This is a common lid switch:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Lid-switch-assembly-item-number-AP3100003.aspx
but may not be yours due to the model number issue.
There are 2 other possibilites also. One being the water level control or pressure switch and the timer assy. Most of the time the lid switch is the failure.
Thanks for using FixYa,
Kelly
Apr 02, 2010 | Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore Front Load Washer Logo
108 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
