Question about Belkin Surf N300 Wireless N Router
Belkin Surf N300 Amber Light Flashing
I've had this router for a year or so. six months ago, I've changed my internet plan for another, meaning thar the router wasn't used for like a month. the technician came and installed the company's own modem. well, that's when things became weird. the ethernet cable that connects the modem to the router is plugged into the 'wired 1' plug, instead of the 'modem' plug that it should be. this way, only computers and my brother's iPhone get the internet connection. other devices only connect to the router, but can't get internet access. I tried to put the ethernet cable into the 'modem' plug, but that way I only got connection to the router and lost all internet access, even for computers and the iPhone. and in all situations, the amber light doesn't stop blinking. what should I do? I've already read the manual, searched the internet and couldn't find any information or 'tutorial' that could help me. hope you guys can, thanks
    Problem Solver:
  • 11 Answers
Hi, did you try out the procedure presented on page 16 of this manual?
http://www.belkin.com/networking/manual/MAN_F7D6301_v1_8820-00697_Surf_N300_N_Router.pdf
Posted on Mar 20, 2014
SOURCE: no internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Posted on Jan 21, 2009
  • 32 Answers
SOURCE: Blinking amber light on modem icon
that means there is usually a problem with your modem. you know how to hook up a router, right? usually you unplug power from both devices, plug in your modem and let it load, then plug in your router. (with some isp's id will work the other way around.
Posted on May 10, 2009
  • 3 Answers
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
Posted on Sep 23, 2009
  • 523 Answers
SOURCE: Belkin f5D8233. have flashing amber router light -
Hi Friend,
Please update the Firmware of the Router from the below website
www.belkin.com/support
Before Downloading the Fireware from the website,plese take the Model number and the Version number of your router.This can be taken from your router at the backside,
If you have any clarification please be feel free to contact us
Regards,
Aysaam
Posted on May 14, 2010
  • 194 Answers
SOURCE: i have successfully installed a
here is the manual http://cache-www.belkin.com/support/dl/8820ed00372_f7d2301_v1_uk.pdf
look up under your wireless security as it isnt set up right either in the router or on your computer.
look at page 8 to 13 of the PDF and follow the set up again. you will need the wire plugged in while doing this process but afterwords you can go wireless after a reboot.
Posted on Apr 30, 2011
How can i get belkin n300 to recognize motorola SB6141?
Well kindly reset the belkin N300, try connect, most probably will get connected....By the by, which mean are you going to connect both? is through lan cable or wifi?
Jul 26, 2014 | Belkin Surf N300 Wireless Router...
Belkin n300 has a red light and willl not connect to the internet
Unplug the router and ISP modem. Connect and cycle the modem if there is a reset. If not wait a few minutes and reconnect everything.
The Belkin also has a reset, but holding it clears all custom settings. While a quick push is a restart.
Oct 26, 2012 | Belkin Surf N300 Wireless N Router
Belkin N300 states authentication problem when attempting to access internet
Folks, There are many situations where You might need to Login Router Dashboard In Order to Change Or Know The settings.For Example Security change, Setup, Router Reset And Troubleshooting Etc.For more details kindly visit
Welcome to This Easy Guide Where We will help You troubleshoot Your Router. If Your Router has quit Working Than This Peace of information is Just about what You Need.
Lets Just Start With Basic Troubleshooting Of Your Wireless Router
For more details kindly visit Belkin Support And Belkin Router Troubleshooting Guides TechVaidya
Thankyou
Aug 10, 2012 | Belkin Surf N300 Wireless Router...
Blinking amber in my Belkin N + no internet connection
If Your Belkin Router Did Not Work Just Reset Your Belkin Router Using The Reset Key and Setup Your Router Again[Don't Worry its Easy and Simple And I Will Guide You How to Setup The Belkin Router. Belkin Support And Belkin Router Troubleshooting Guides TechVaidya Let's Learn How to Reset Belkin Wireless Router To Default Setting -
  • Press the Reset Key Using a Pen At The Back Of Your Router And Hold For 30 seconds.
  • Restart Your Router And Modem And Good Job For More steps Visit How To Reset Belkin Wireless Router To Default Settings?
  • Your Belkin Router Has Been Reset And Now You Can Setup Your Belkin Router in Simple Steps just Follow This Step By Step Guide To Configure and Install Your Belkin Wireless Router Please Visit How to Setup and Configure Belkin Wireless router?
Nov 05, 2011 | Belkin (F5D8235-4) Wireless Router
How do you find the DNS server address on a Belkin Surf N300
The DNS server address comes from your Internet Service Provider. When you go to the command line and type in ipconfig /all you will see DNS Servers and their addresses there
Sep 07, 2011 | Belkin Surf N300 Wireless N Router
And orange bliking light came on what does it mean
If your belkin wireless router is flashing orange, it more than likely means it was hit by a power surge or got wet and popped the circuit on the mother board of the router. Took mine apart and found where the circuit had been blackened by power surge hitting it. I was able to salvage one important thing was the antenna that can be adapted to other systems if you know what your doing.
Dec 12, 2010 | Belkin Surf N300 Wireless Router...
Wireless amber light flashing problem
If the wireles light is flashing Amber .. Some one outside your house is trying to access the Wireless network . If it is always flashing amber.. try with a Firmware update available in belkin.com/au/support.
Thank You
Jul 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Surf N300 Wireless N Router Logo
173 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
