Question about Brother HL4040CN Laser Printer
A sping from the paper tray poped out ..I dont know where to put it back...... the paper does not go up so it can be pulled and print and i hear click click .....model is Brother HL 2540 ...do I have to buy a brand new one ?
    President:
  • 2,306 Answers
You may need a paper tray, about $20.00, that spring goes on the left and if it's off the tab is probably broken. Look in your manual for accessories and you should have the part number.
Posted on Aug 31, 2009
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Pinter tray is showing as empty when full.
Hi
I had the same problem, what you need to do is ruffle up the paper abit dont put it in so neat , for some reason the sensors are notrecongnising the paper (dont know why) i have used the same before...
good luck
Abdullah
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
No paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Jul 23, 2008 | Lexmark E234 Laser Printer
Paper tray noise.
I actually fixed mine. I found this post and it did not fix the problem. Here is what happened. I was printing several documents and the paper ran out. I pulled the tray out at a slight angle this caused the try to catch on the paper level sensor tab and pulled it out of place. Since this was out of place when the printer lifted the paper, the printer did not know that the paper was up and would keep trying to lift it, hence the slipping of the cogs/gears and the load clicking noise. This sensor is a black tab on the printer by the rollers that pick up the paper. So to fix it this is what I did:
1. Unplug it!
2. Unplug it, seriously.
3. Unscrew the silver bar on the bottom.
4. Take the rollers out, the blue piece holding them in is flexible.
5. Note the two black pieces that move back and forth. Observe that one of them has a spring and this one slides between one of the sensors on a breadboard. Remove the spring and don't lose it!
6. The other tab is the one that caused my problem. If you have the same problem it won't go all the way back and slide between the other sensor. So to correct this you need to lift or push it back into place so that it will move between the sensor. If you do this correctly it won't move that much, just enough to do its job.
7. Put the spring back on.
8. Put the rollers back, there is a tab of the white part that slides in like a key hole.
9. Reattach the silver bar. Keep in mind the grounding wire, make sure it is on top, visible to you when screwing it in.
10. Insert tray and print.
Happy printing!
Jun 02, 2008 | Brother HL 5250DN Laser Printer
Brother HL4040CN Laser Printer Logo
141 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
