Question about Refrigerators
Freezer/refrigerator not getting cold frost buildup in back of freezer
Amana tz23ql not getting cold frost building up on rear wall of freezer
fridgetech
  • 473 Answers
SOURCE: Frost
It has a defrost problem.  1. Defrost thermostat  2. Defrost timer.  3. Or Defrost heater.
Posted on Oct 25, 2007
sdmc73
  • 121 Answers
SOURCE: warm fridge
check the fan in the frezer and check the defrost
Posted on Nov 29, 2008
  • 15 Answers
SOURCE: freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
Posted on Jun 01, 2009
pappapumpdaf
  • 635 Answers
SOURCE: Amana AFB2534 freezer is regularly getting frost
This is either of three defrost parts. The timer, heater or defrost limit switch. Most amana's I fix have a bad limit switch which is clipped to the freezer coils directly. Spin your defrost timer till it clicks and check the same frost laden wall to see if the frost starts to steam and melt. If not, unplug the fridge, then try disconnecting the limit switch and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Posted on Mar 05, 2010
  • 2468 Answers
SOURCE: Frost Buildup in freezer section
check the defrost heater in the evaporator compartment at the rear of the freezer for continuity,then check your defrost control if the heater is o.k. be it either an adaptive defrost or a timer type defrost control
Posted on May 23, 2010
Amana refrigerator ars2365aw refrigerator/freezer works perfectly for a day or two then stops cooling. Compressor and fans are still running. I will unplug it for a days, plug it back in then it will work...
if your freezers back wall has a layer of frost build up on it,that means the defrost heater or thermostat that controls this heater is bad,if theres an ice buildup on the evaporator coils it cant blow cold air into the unityou need to find out whats bad as it can no longer defrost,when you shut it off for a day you are defrosting the unit,then the frost and ice again cover the coil when you plug it back in
May 12, 2011 | Amana ARS2661BS Side by Side Refrigerator
Amana AFB2534 freezer is regularly getting frost buildup at the back. first 2 times it was so bad that it blocked the vent & prevented cold air from reaching the refrigerator. Freezer just doesn't seem...
Mar 05, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
The freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Warm fridge
Nov 29, 2008 | Amana Refrigerators
Freezer not cold enough
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Amana ARB2205C Bottom Freezer Refrigerator
FRIDGE FREEZER BUT FRIDGE STOPPED WORKING FREEZER WORKING OK
look on the back wall of the freezer is there snow? if so you have a defrost component out (timer, limit, or heater) the fresh food compartment gets cool air from the freezer so check for blocked air pathways the build up of frost in the freezer stops air flow so you will be cold on freezer side and warm on ref side
Apr 24, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
