Question about Canon F-719sg Scientific Calculator 4178b001
Ram test error
How can I get solve it
  • 457 Answers
Its broken and there is no simple solution for your problem. Technically, a repair may be possible, but you'd need some spare parts, decent soldering equipment suited for surface mounted devices, and a lot of experience in handling them.
I understand your sentiment (I hate to throw away things, too!). However, the calculator comes new for below USD 16 even if you mail order it from Canon directly (my estimate is, you can get it for around USD 10 from a local office suplies shop). Ordering the spare parts alone, even if you can identify them, will already exceed the costs for just buying a new calculator, so its a total loss.
Posted on Mar 20, 2014
Motherboard Led codes
Is this a bios error code onthe onbaord diagnostics?
As this is a server board be careful - reset the bios to defaults is the first step in solving motherboard issues.
Remove all cards and begin testing - remove all ram chips except one and test replacing stepwise until you have isolated the issue - usually the bios error code is the last item to pass before failure.
Looks like it could be DMA controller failure but you would need the manual for the board to be sure.
Jan 30, 2013 | Tyan Computers & Internet
How can we solve memory error front panal LED 1-3 blinking
make sure the ram modules have a dust free secure seatings and the ram sockets are clean along with the cmos battery some motherboards cmos batteries are soldered in
also test all electrical lead connections for secure dust free connections this might take some time to check
hope it helps
Apr 22, 2012 | Dell Precision T3500 Computer Workstation...
On pwr up 3 beeps
Three beeps means there has been a base memory read/write test error.
Replacing the RAM usually solves this error. You might just need to take off the memory modules and fit them in again.
Align the module and just push in; the clips will lock in if the allignment is fine.
Jan 11, 2011 | Computers & Internet
Is there a fix for biome-1 error
I purchased 2x2gb Ram sticks... along with a new case, I had them all installed by a client of mine who owns an IT company and I had the pleasure of waiting around for 4 hrs while they ran through all the RAM tests... PC works fine however as soon as I'm away for it for any length of time I come back and its continually rebooting. diagnostic says RAM test failure Biome-1.
Removed the RAM and fitted fresh, problem solved.
Hope that helps.
Jan 03, 2011 | HP Pavilion a6712f-b PC Desktop
Getting error message on ibm x3400 Fatal Error Controller Monitor Failed Controller Not Started
dear sir in my server IBM X3400 has a problem due to RAM it might be corrupted or out of order bcause system gives continues beep when i change the RAM with HCL 1 GB DDR2 (Previous RAM was also 1 GB) it gives error:
waiting for controller to start
FATAL ERROR: controller kernel self test failed
<< press any key to continue>>
please solve the problem
Oct 28, 2010 | IBM x3400 Server
How do you solve: c000021a fatal system error the windows logon process system process terminated unexpectedly with a status 0xc0000005 (0x0000000 0x00000000) on a dell dimension 5000 using xp home...
most likely the ram memory is bad, or the windows file system is corrupted. test the ram with memtest86 (http://www.memtest86.com/) and/or replace it. if the ram is good, all you can do is backup the files and reinstall windows. to reinstall windows, use your disks, or press one of the following keys when the computer boots up:
sony = F10
hp = F11
Nov 18, 2009 | Computers & Internet
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Memory write/read error
Down load memtest from here
http://www.memtest.org/
and follow instructions to make a bootable iso. This will test the ram to see if it is producing errors at all.
Should be able to run it for an hour without even 1 error. Any at all and ram is faulty/not setup correctly.
Post back with results and we will take from there :)
Jan 07, 2008 | Dell Inspiron B130 Notebook
Canon F-719sg Scientific Calculator 4178b001 Logo
47 people viewed this question
old marine
old marine
