Question about Hardware & Accessories
Need instructions for amplicorp magneraser model 200c
I know it erases magnetic tape on the reel
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
robotek
  • 1512 Answers
SOURCE: Teac X1000R Reel to reel
Hi there. It will need a new pinch roller, and has a bias oscillator. problem. From memory, they use a module for the oscillator, and the pinch rollers are easy to get. Sorting out the bias may be the problematic part, and you will need to recalibrate the bias traps and controls if you want max performance from the unit once repaired. I would go about checking things like intermittent tape bias switch, and try wriggling the record play switch( internally) and see if you can get erase and rec back. Noisy intermittent switches can caused the symptoms you have.
If you are able to, I would be seeking a refund. If not, then repairs are feasible. Let me know where you are and I can help you find a repair guy. Cheers
regards
robotek
Posted on Sep 07, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: reel to reel tape pioneer model RT1011L
http://www.hifimanuals.com/proddetail.php?prod=2059
Posted on Jul 04, 2009
  • 141 Answers
SOURCE: I have a TEAC reel to reel stereo tape deck, Model
That's a rarity but easily fixed. Before pulling anything apart spray some penetrating oil (WD-40) or similar into a small container. Then with a cotton bud soak the tip in the penetrating oil and apply it to the base of the capstan where the bearing is. Allow this to sit for a few hours and even repeat it if it looks to have soaked the oil up. NOW, with the power lead out of the wall socket remove the top cover of the deck. You will have to remove a few knobs and mode switches too. Now see if you can rotate the capstan flywheel by hand. It might take a bit of pressure to get it to turn but once it does keep going until it starts to rotate freely.
By the way, check that the capstan drive belt is in one piece and not slipping first.
If it's running freely then reassemble the cover and other pieces tyhen put a few drops of light oil on the capstan bearing (sewing machine oil is ideal) Do this because penetrating oil will dry out after a while. That should fix it.
I'm assuming you know exactly how to thread the tape through the machine. Don't forget to position the stop lever on the upper side of the tape otherwise nothing will operate. If you are unsure about that write back and I will elaborate.
Posted on Apr 24, 2010
  • 5 Answers
SOURCE: tape machine; Realistic 909 model, reel to reel
Check to see if the belt is off or broke. That could one reason.
Posted on Sep 17, 2010
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
How do I 'erase' a tape for a Dictaphone 1710?
I used to use "bulk tape erasers" to do the job in less than a minute for standard cassette of any length, 8 track and even reel-to-reel magnetic recording tape. Otherwise, you'll need to record "silence" over the entire length of tape. That will be time consuming - but will make the next recording clearer as opposed to just recording the dictation over the old recording.
Here's a link to some I found on Google. I'm sure there are plenty of other places to check (like ebay or craigslist) too. Don't forget to demagnetize the recoding head too! There are tools for this that will dramatically improve the sound captured on the tape. Here are a few I found. Finally, physically scrubbing the head with a plain old Q-Tip dipped in denatured alcohol to loosen dirt and grime that collects on the head and anything that comes in contact with the tape itself. You can get that, here.
Doing this along with replacing old tapes (they get stretched out, scratched, and dirty) regularly will keep the audio sounding crisp and clear.
Sep 25, 2013 | Dictaphone 1710 Minicassette Mini cassette...
Typewriter won't erase letters completely.
Correction tapes do have a shelf life and can dry out. You should try replacing the correction tape and see if it is better. If that does not fix it, does the tape lift up high enough to cover the entire letter? If not, you have a lifting problem and will need a tech to fix it.
May 28, 2010 | IBM Wheelwriter 6 Typewriter
I have a broken VHS cassette.
You can remove the 4 or 5 screws at the bottom of the tape, turn the tape over CAREFULLY pull the top off. If the tape pulled out of the end of 1 spool, you have to remove the clip in the tape hub, reinsert the tape and snap the clip back in. Holding the tape door open so as not to catch tape, put top back on and replace screws. Hope this helps.
Aug 08, 2009 | TDK T 120HS VHS Tape
Reel to reel tape payer
i changed the main drive belt on a reel to reel stereo tape recorder model no A1340 serial no 3642 there is a small wire arm under the play/ record head platform . I believe its the record switch . the arm is not straight looking at machine the arm is straight from switch and go at a 45 degree angle then turns straight and then angles up about a half inch or less . i need to know how to replace this arm ( switch) back into the the head platform so i can start using this recorder
do u have rhe service manual for this machine if so ca i get a copy ?
thanks
Arthur Hathaway
Nov 20, 2008 | Audio Players & Recorders
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Akai reel to reel GX230D
Try demagnetizing the heads with a head demag device. This is not the same as a bulk tape eraser or a tape demag device.
Oct 17, 2007 | Audio Players & Recorders
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
