Question about Pool & Spa
Spa won't turn on
Everything electrical is good but control won't turn on
Dreammaker x-400 clicking sound and pump surge
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Apr 11, 2017 | Pool & Spa
I have Jandy AquaLinkRS4 control panel, 14 years old. Never any problems until now. Recently the spa randomly turns on. The spa has never been programmed to turn on and off. Some times when everything...
No. Sounds like you have software or electronic problems. You can have those boards rebuilt for $300 hundred dollars so if you need a new one, insist your technician send it in for a rebuild rather than replace it which will cost much more!
Apr 12, 2011 | Jandy Aqualink Rs4 One Touch Control...
My dreammaker spa has power and lights but the pump won,t turn on.it makes a sound for a few seconds like it is trying to turn over then it stops.it was recently running .
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
27 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
