Question about Samsung Refrigerator Ice Maker - DA97-07365A
WATER DOES NOT STOP OVERFLOWING IN THE ICEMAKER
WATER OVERFLOWS IN THE ICEMAKER
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
Icemaker overflows water , repairman has replaced the icemaker twice, after this last time, it started making 1 tray of cubes per week, then after about 2 weeks, started overflowing water again.
Good day,
If it is erratic as you describe and replacing the ice maker twice has not resolved the issue it would make sense to replace the water valve in the back rear of the machine, if it hasn't been done so yet. It's the flakiest part of the system and has the highest failure rate. It's been known to fill too little, to much, and sometimes not at all.
May 26, 2010 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
The belt broke, it was replaced, but afterwards its overflows,
If water is overflowing check the small plastic line going from the bottom of the tank to the water level switch. It could be disconected. To check the water vales, set machine to fill, while the water is running into the tub unplug the power cord from the wall, the water should stop, if not the water valve is faulty.
Oct 11, 2009 | Speed Queen Washing Machines
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
Jun 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Water overflowing in ice maker.
I just replace my kitchenaid icemaker. My model is 4317943. And it comes with a sheet of menu. I scan a portion and hope it will help.
Apr 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid dishwasher overflowing; water will not stop coming in
If it is filling when the dishwasher is off then you need a new water valve.
Jan 13, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung Refrigerator Ice Maker - DA97-07365A Logo
32 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
