Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
I can't figure out how to get my Hoover Fusion Cyclonic canister open to empty it
I have pressed the button on the front but all it does is raise/lower the handle.
Read the owners manual it will tell you
Posted on Mar 21, 2014
  • jcla
    jcla Dec 27, 2014
    There should be a button on the handle, and one on the cannister. As you push the one on the cannister you may also have to pull the cannister outward. It will not just pop out. Or as above, check the owners manual.
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: manual
Go to hoover.com, scroll down to downloads, enter your model number which is located on the metal tag either on the back or bottom. If it is available you will be able to download it.
Posted on Feb 29, 2008
SOURCE: Hoover Cyclonic Fusion Vacuum overheats and shuts off.
If it gets too hot it will shut down for about an hour...it does that to protect the motor. A lot of tools and work appliances seem to have that feature nowadays.
Posted on Mar 24, 2009
SOURCE: hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
Posted on Aug 11, 2009
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
Is my model nno. US183900 S/N 080600079068 still under warranty? I have a broken hinge post in the bottom cover of the dirt canister. Thank you.
The Hoover Fusion Plus Cyclonic Upright Vacuum has a 1 year manufacturers warranty from date of purchase. You need to check your reciept to see if it's under a year old. Then go to the Hoover.com web site to find the closest Hoover warranty service center to where you live. Bring the proof of purchase and the vacuum to them.
Apr 08, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Please tell me how to empty a Dyson Dc05. I don't have instructions. Thanks
Hi its Darran at Dyson.
To empty your DC05, press the button on the top of the machine at the front of the carrying handle to open the lid. Then lift off the cyclone top and bin assembly. Over a dustbin, press the button on the front of the cyclone/bin assembly to separate the two sections. You can then tip the contents of the bin directly into the dustbin.
For full step by step instructions on how to empty the bin, please visit www.dyson.co.ukl/support.
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson DC05 Bagless Canister Cyclonic...
When I turn on the vacuum dust blows out of the front.
THERE IS A PAPER FILTER THAT IS CLOGGED WHEN YOU PULL THE PLASTIC CONTAINER OUT TO EMPTY IT LOOK CLOSELY ON THE CONTAINER BOTTOM THERE IS SOMETHING THERE TO RELEASE AND THERE IS A FILTER CLEAN IT AND YOUR BACK IN BUSINESS
Dec 19, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
My fusion just stopped. i was vaccuuming and it
One item to check is this: This unit has a temperature overheat device.
Unplug the unit for 20 minutes, then plug in and turn on the switch. If there was a blockage in the hose/cup/filters, this could cause the overheating.
If this does not resolve the problem, it will need disassembled and checked with a continuity meter to determine the component that failed (motor, switch, cord, or TCO)
Oct 25, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Cannot remove dirt cup for emptying
It has a release button some where , you need to find it...(my wife had same issue...i left her to find it :)..
hope it helps...keep the hope :)
May 19, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Manual
Feb 29, 2008 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
119 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
