Question about Brother Sewing Machines
Needle broke off in sewing machine
No not where the needle attaches but down inside I can't seem to figure out how to get to it...took off/ out bobbin ect
  • 77 Answers
Usually they fall to the bottom. Slightly shaking the machine can tell if it is still there. A small magnet is sometimes helpful.
Posted on May 17, 2014
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Posted on Apr 19, 2009
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
I have a Janome Memory Craft 4900. I broke a needle while sewing in a zipper. I replaced the needle,but now the machine makes a medal scraping noise when I sew. I took off the needle plate and bobbin...
did you find the tip of the needle? Also you may have a nick in the metal where the needle hit and broke.It can catch on other parts and need to be sanded or replaced.One time I had this issue and I found the tiny broken tip under my bobbin case.
Jan 18, 2014 | Janome Sewing Machines
I was sewing just fine then the needle broke ... I replaced it only to find that the next needle broke too. It seems that the needle just hits the rotating metal below the bobbin each time it goes...
First make sure there are not bits of needle left in the needle holder, or down in the bobbin area. Take out the bobbin, take the bobbin carrier out. Take off the foot. You need to see.
Look carefully at the shuttle while rotating the hand wheel in the direction of sewing until the needle is at it's lowest position. Where is the shuttle's Point? (past the needle? or way behind the needle?)
I think your machine is out of time. You may need to take it in for timing.
Nov 10, 2012 | Sewing Machines
Feeder dog is in reverse and thread won't feed through bobbin..
it would really be a good idea to have the machine serviced at a sewing
machine shop
May 05, 2012 | Sewing Machines
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
Needle hits the white plastic where the bobbin case sits.
It may be as simple as you didnt get the needle pushed all the way up in the needle bar. Get new package of needles and try a new needle and make *sure* it goes up as far as you can push it. the reason I suggest a new pkg of needles is if one is bad in the pkg, they are probably all bad. If that doesnt fix it then the needle bar timing/height is off and need to be repaired/adjusted by a tech.
May 05, 2010 | Elna 7200 Computerized Sewing Machine
I broke a needle on something hard. After I replaced the needle it wouldn't go all the way down. I took the screws out and removed the piece that holds the bobbin. I can't seem to get it back in so that...
This sounds like your metal plate needs adjustment. Loosen the screws and adjust it until the needle goes all the way down. If that doesnt work, ensure that your bobbin case has been aligned properly.
Apr 07, 2010 | Brother CS6000i Computerized Sewing...
My needle broke all of a sudden
The needle might not have been fully seated and tightened down - or vibrated loose and dropped down a bit and got hit by the bobbin shuttle. My mom used to soap or wax her needles (lower by hand into a candle or bar of Ivory) to sew stuff like DUCK, Burlap or thick denim.
Try thisusing a new needle (they're cheap) but be SURE that needle is all the way up into the carrier ;-)
Mar 26, 2009 | Yamata FY101-1A
Breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Feb 14, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
14 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
