Question about Canon P1-DHV Calculator
Print head motor constantly running - Canon P1-DHV Calculator
I received some color photos via email...when i tried to print them, they all came out like a water color all running together.
clean your print head. Pull the ink cartridge/print head out and dab a Q tip in distilled water and run it over the very small piece of foil that is the ink jet head in one direction, like your painting it. you will use about 15 to get it clean as it will constantly bleed ink onto the Qtip. When its clean, you should put it back in and run a printer head cleaning cycle through the printers tool section. It will print each color a few times on a line and that should clean the head internally.
Jan 31, 2018 | Office Equipment & Supplies
When printing clip art, photos, etc. my graphics constantly have a series of evenly spaced lines crossing the art work. I can't find any printer head cleaning prompts. Even when I replace the ink...
Hmm, nozzles are blocked. Try Isopropyl Alcohol on a cotton tip or better still, a rag piece and run under the print head.
If this doesn't help, maybe this video will -
https://www.youtube.com/watch?v=CspEIN8EsZ4
Lastly, the printer should have come with a program that can clean the print heads.
Dec 24, 2017 | HEWLETT-PACKARD Hewlett Packard Officejet...
Hardware alarm 0253-131-000002-3790-1500 After warmup this flashes on the screen.
The hardware alarm you are seeing on the 2265+ indicates the printer is experiencing a "horizontal task error" ie the printer is not able to move the print head or is not able to detect the print head is moving, things you can check to resolve this problem are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
If the problem persists it is likely the printer has developed a fault, check the following
  • Worn or damaged timing strip
  • Worn or damaged carriage shaft
  • Fault timing sensor
  • Faulty carriage motor
  • Damaged print head cable
  • Incorrectly connected print head cable
  • Faulty interconnect board
  • Faulty Main Board
Jan 21, 2011 | TallyGenicom 2265+ Matrix Printer
On my mfc 260C the black ink print keeps fading to nil but is ok each time for about 20 pages after pressing the ink management button. No problem ever with colour print.
You may need to run the cleaning fuction on your printer to clean the black print heads.
Every month (once a month), you need to clean your print heads to prevent your heads from clotting.
You are now seeing the symptoms of what happens when you do not constantly maintain your cleanliness of your print heads.
If that does not work, try buying a new black cartrige to see if the original black cartrige is defective.
If the above does not work, you may have a failing carrage and may need replacing
But do all of above first and get back to me with what happend during your diagnosis of your issues.
Jun 14, 2010 | Office Equipment & Supplies
Error-check printhead path 2
After plot one ploter going to print head check mode on dsj 1050.
May 17, 2010 | HP DesignJet 1050c plus InkJet Printer
98 Ford Taurus SE needs water constantly, could
could be a leaking head gasket but the heater sounds like its air locked have the head gasket checked
Apr 02, 2010 | 1998 Ford Taurus
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon P1-DHV Calculator Logo
old marine
old marine
