Question about Rochester Shoe Tree Company Red Cedar Tie Rack
Need more hangers for tie rack
Need replacement hangers for Rochester tie rack
How do you replace the rack and opinion on a 92 cutlass ceira
Here you are - power rack & pinion.
Except 2.2L and 1993-96 3.1L Engines
See Figure 1
  1. Raise the intermediate shaft seal and remove intermediate shaft-to-stub shaft pinch bolt.
  2. Remove the air cleaner and disconnect the pressure hoses from the steering gear.
  3. Raise and support the vehicle on jackstands, then remove both front wheel and tire assemblies.
  4. Remove the cotter pins and nuts from both tie rod ends. Using tool J-6627 or BT-7101, press the tie rod ends from the steering knuckle.
  5. If equipped with an Air Management pipe, remove the bracket bolt from the crossmember.
  6. Remove the 2 rear cradle mounting bolts and lower the rear of the cradle about 4-5 in. (102-127mm).
WARNING
If the rear of the cradle is lowered too far, the engine components nearest the cowl may be damaged.
  1. If equipped, remove the rack and pinion heat shield.
Fig. Fig. 1: Power rack and pinion assembly
  1. Remove the rack and pinion mounting bolts, then the gear assembly through the left wheel opening.
To install:
  1. Install the gear assembly through the left wheel opening and install the mounting bolts.
  2. Install the heat shield.
  3. Raise the rear of the cradle and install the mounting bolts.
  4. Install the bracket bolt to the crossmember under the air management pipe.
  5. Install the tie rod ends to the steering knuckles, install the retaining nuts and insert new cotter pins.
  6. Install the front wheels and lower the vehicle.
  7. Install the high pressure hoses to the steering gear and install the air cleaner.
  8. Install the intermediate shaft seal and the intermediate shaft-to-stub shaft pinch bolt.
2.2L Engine
  1. Disconnect the negative battery cable.
  2. Install an engine support fixture J-28467-A, or the equivalent.
  3. Raise and safely support the vehicle.
  4. Remove the tire and wheel assembly.
  5. Remove the intermediate shaft lower pinch bolt.
  6. Disconnect the intermediate shaft from stub shaft.
CAUTION
Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury.
  1. Remove the exhaust pipe hanger bracket near rear of frame including the brake line retainer and rubber exhaust pipe hangers.
  2. Remove the engine and transaxle mount nuts at the subframe.
  3. Support the rear of the subframe with jack stands.
  4. Remove the rear subframe bolts and discard.
  5. Lower the subframe for access to rack and pinion.
Do not lower the rear of the cradle too far, as damage to engine components nearest the cowl may result.
  1. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  2. Disconnect the power steering lines from the steering gear.
  3. Remove the rack and pinion mounting bolts and nuts.
  4. Remove the rack and pinion through left wheel opening.
To Install:
  1. Install the rack and pinion through left wheel opening.
  2. Install the rack and pinion mounting bolts and nuts and tighten to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm) on the pressure line.
  4. Install the power steering line clip to steering gear.
  5. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  6. Raise the subframe into position and install new frame mounting bolts. Tighten the bolts to 103 ft. lbs. (140 Nm).
  7. Remove the jack.
  8. Install the engine mount and transaxle mount nuts and tighten to 39 ft. lbs. (53 Nm).
  9. Install the exhaust pipe hanger bracket near the rear of frame including brake line retainer and rubber exhaust pipe hanger.
  10. Connect the intermediate shaft to the stub shaft and tighten the pinch bolt to 29 ft. lbs. (40 Nm).
  11. Install the tire and wheel assembly.
  12. Lower the vehicle.
  13. Remove the support fixture.
  14. Connect the negative battery cable.
  15. Refill the power steering reservoir and bleed the system.
  16. Check the front end alignment and adjust as necessary.
3.1L Engine (VIN M)
  2. Remove engine torque strut from engine.
  3. Install an engine support fixture J-28467-A, or the equivalent.
  4. Raise and safely support the vehicle.
  5. Remove the tire and wheel assembly.
  6. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  7. Remove the center engine and rear transaxle mounts from the frame.
  8. Remove the intermediate shaft lower pinch bolt.
  9. Disconnect the intermediate shaft from stub shaft.
CAUTION
  1. Remove the brace bolts and brace, including brake line brace.
  2. Support the rear of the subframe with jack stands.
  3. Remove the rear subframe bolts and discard.
  4. Lower the subframe for access to rack and pinion.
  5. Remove the steering gear heat shield.
  6. Remove the clip holding lines at rack assembly.
  7. Disconnect the power steering lines and O-rings.
  8. Remove the rack and pinion mounting bolts and nuts.
  9. Remove the rack and pinion unit through the left wheel well.
To Install:
  2. Install the rack and pinion mounting bolts and nuts and tighten the mounting bolts to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm). on the pressure line.
  5. Install the steering gear heat shield.
  7. Remove the jack.
  9. Install the brace and bolts including brake line brace.
  11. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  12. Install the tire and wheel assembly.
  13. Lower the vehicle.
  14. Remove the support fixture.
  15. Connect the negative battery cable.
  16. Refill the power steering reservoir and bleed the system.
  17. Check the front end alignment and adjust as necessary.
Nov 01, 2015 | Cars & Trucks
How to replace rack an pinion cutlass ciera 1992
You aren't saying what engine is in it, or whether it is manual or power steering. Here is the R/R procedure for power steering rack for all engine sizes.
See Figure 1
WARNING
To install:
2.2L Engine
CAUTION
To Install:
  7. Remove the jack.
3.1L Engine (VIN M)
CAUTION
To Install:
  7. Remove the jack.
Vt commodore rack boots
Vt commodore steering Rack boots always rip and tear,the racks always tend to leak from the internal seals.
So if this the case with yours I would recommend you just get a reconditioned steering rack and fit it but once the rack is replaced you will also need to do a wheel alignment.
steps to change rack .
1.raise vehicle on hoist
2.remove front wheels
3.remove tie rod end split pins
4.undo tie rod end nuts and inner nuts on rack ends
5.release tie rod end from hub.
6.centralise steering wheel and remove keys from ignition
7.count the number of turns on each side that tie rod come off and write down .
8.undo the 2 metal pipes that go into the rack feed and return lines and make sure u have container under the vehicle to collect old fluid.
9.undo the 13mm nut and bolt that mounts the rack to the steering colum shaft.
10.undo the 2 *19mm bolts and nuts that mount the rack to the crossmember.
11.gentle wiggle the rack and it will come away.
12.follow these steps in reverse when fitting new rack.,make sure you replace the oring seals .
13.you will need to get a wheel alignment done..
Feb 12, 2014 | Cars & Trucks
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
I need to rplace the inner tie rods.
Inner tie rods rarely if ever need to be replaced in my experience: outer tie rod ends are far more common. Its not impossible so here's how.
1. remove the tie rod ends from the knuckle.
2. remove the clamp for the rubber bellows on the rack ends, and slide the bellows down the rod.
3. Turn the rack to fullleft or right as needed to get access to the inner rod end that screws into the rack.
4. There's a lock tab that has to be bent flat. This locks the rod end into the rack.
5. You'll need a (probably) 32mm wrench to undo the rod end from the rack.
6. Note how the lock tab is fitted to the rack/rod end.
7. Put in the new tie rods.
If your garage mechanic told you the inner tie rods are worn out, I'd ask why they think so. At step 4. above, try rotating the rod. This should be quite difficult. There should be NO evidence of slop or wear in the inner joint. What more commonly wears is the bushes on the end of the rack. These bushes are easily replacable with the rack in the car.The tie rods have to be removed to do this. So, when the rods are off, inspect the rack bushes for wear.
SD
Jun 25, 2011 | 2003 Mitsubishi Outlander
Is an inner tie rod, part of the rack and pinion steering?
the inner tie rod is the joint right at the end of the rack,inside the gaiter/boot,the outer is called the track rod end.
Aug 26, 2010 | 2006 Pontiac Torrent
I just bought a 93 honda civic and I took it to goodyear and they said I needed my tie rods tightend is there a way I can do it myself?
Yes. If it's to correct alignment, the inner tie rod shaft has to be moved into your outer tie rod and then tightened. this is all done from the wheel area.
If it is to correct play in the steering, then this should apply.
The inner tie rod connection to the Rack unit is hidden by the rack boot which will need to be removed from the Rack unit but not completely removed from the shaft, just pushed over out of the way while working on the inner tie rod adjustment. The large nut on the end of the inner tie rod will have to be loosened & checked, for any damage, then reinstalled & tightened to the correct amount necessary to cause sufficient drag on the inner tie rod but not too much to restrict it during normal use.
You may even want to consider a remanufactured Rack unit if you have too much slack in the steering. Tightening the Inner Tie Rods doesn't replace the seals & rebuild the remainder of the Rack & Pinion, yet these parts all have the same amount of wear on them that the Inner Tie Rod does.
Manuals available w/step by step instructions for your vehicle at parts stores. good luck
Feb 15, 2010 | 1993 Honda Civic 4 Door
Replace rack/pinion
The book calls for about 5 hours labor with a lift, air tools, and experience. It's a tough job. Here are a few tips, Take the lines loose from the rack; not the pump. With the tires off, Remove the nuts from the outer tie rods.Run the nuts back on the tie rods stud and hit the steering knuckle where the tie rod's stud goes through.This will free the stud. Remove the steering shaft from the rack.(take the bolt all the way out.Remove rack mounting bolts. Twist,pull ****,and fight the rack out the side of the car with the most room. The new rack will have inner tie rods already installed. Make sure the new rack is centered.(Turn left then right count the turns then center same # of turns from left to right). Count the threads or measure from the outer tie rod's jam nut to the last thread on the inner tie rod.(you can leave the jam nut in place and take the outer tie rod off and measure from the jam nut to the end of the rod.)Install the outer tie rods. Replace rack in car. hook up steering shaft.Bolt up rack. Hook up lines. Add fluid and work rack back and forth to bleed air. recheck fluid. Have it aligned. (or just take it to a shop.This job is going to be a nightmare!!!)
May 23, 2009 | 1999 Ford Taurus
Rack pinions and bushing installement
pretty decent job ahead first jack up car support with jack stands remove front wheels remove nuts on tie rod ends remove tie rod ends from spindles with tie rod end tool or tap with malet were they sit to loosen them hit the spindle area not the tie rod or tie rod threads then dissconnect power steering lines from steering rack also disconect steering linkage to rack there should be 2 main bolts holding assembly to frame remove them should free rack i know that car may have a unique design were u may have to remove inner tie rod ends first if it has those round bushings that always go bad disconect inner tie rod ends behind engine on top of steering rack then remove rack from wheel well replace those inner tie rod bushings u may be able to leave outer tie rod end connected to spindles and u may be able to get to the sterring rack from behind engine good luck
Mar 28, 2009 | 1997 Chrysler Concorde
I need to replace the inner tie rods on my 97' conti......need a diagram of how to and any other info pertinent to the job - Bair
If this is a rack and pinion type steering, in order to remove the inner tie rods you will first have loosen the jam nut at the outer tie rod end,next unbolt the outer tie rod from the steering knuckle, unscrew the outer tie rod end off (be sure to count how many turns to remove), next remove the inner bellows boot (black boot) from the tie rod / rack and pinion, next is to unscrew the inner tie rod from the rack assembly (the do make a tool for this to make it easier) but if you do not have the tool,you can sometimes use a big pair of channel locks or a big enough wrench to fit on the fitting on the inside of the inner tie rod, and just unscrew the inner tie rod (normal left=loosen, right=tighten). Hope this helps. Would also recommend having it aligned after you are finished.
Mar 12, 2009 | 1997 Lincoln Continental
Rochester Shoe Tree Company Red Cedar Tie Rack Logo
Top Rochester Shoe Tree Company Home Experts
Donni Steen
Tom Chichester
Are you a Rochester Shoe Tree Company Home Expert? Answer questions, earn points and help others
