Question about Zebra MT2070 Barcode Scanner PN KT2070SD2078C1WW Barcode Scanner
Mt2070 won't turn on
Battery is full, but unit won't turn on.
My 1997 Suzuki Bandit600 won't start, the battery
during the battery replacement did you manage to either forget or damage a wire that powers up say your ignition module... ?
Sep 15, 2014 | 1997 Suzuki GSF 600 S Bandit
Neato vacumm won't turn on
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Apr 17, 2013 | Neato Vacuums
Scanner services is not running
What is the scanner hooked to? IF this is an error on a pc, we need to know what operating system you are using
Apr 03, 2013 | Zebra MT2070 Barcode Scanner PN...
How to reboot Motorola MT2070 Barcode Scanner
Press and hold the 2 key and the scanner trigger for 5 seconds for a warm boot, and 10 seconds for a cold boot. Be advised that a cold boot will erase all user data programmed into scanner.
Mar 13, 2012 | Motorola Computers & Internet
Backup power ends quickly even with new battery
What is the load on the unit? How old is it?
The symptom can occur if the load is too large. It will also happen when the unit reaches a certain age.
I've found that the low-end consumer UPS's should be replaced when the battery fails. The charging circuitry usually fails to charge the battery even with a new battery soon after the replacement.
The way I check if the battery or the UPS charging system has failed is with a voltmeter to give the current voltage and a variable DC power supply (whatever is appropriate for the battery) to attempt to charge the battery. I can watch the battery discharge with an oscilliscope if I want a full trace of the unit.) Charge the battery fully then watch the unit over time. If the battery itself is bad, you won't get the full charge or it will discharge as soon as it is removed from the power supply.
I hope this helps.
(the server UPS's tend to be a better choice if you want to replace the battery and keep the UPS.)
Aug 21, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
I am trying to charge my cars battery but I am not sure where to put the 3 way switch.
Best solution is to use the Auto mode, since the unit will monitor the battery, and automatically switch to trickle charge when the battery is full. In the Auto mode, it won't overcharge the battery.
Feb 28, 2011 | Schumacher 10 Amp Fully Automatic/Manual...
USB is connected, battery is full whereas while we want to switch on it is totally dead. One day only I heard from the very next day it is not functioning.
I came across you question while looking to see if I could find answer to my problem with this model. But after all this time (~5+years) may be too late for you.
When you have the USB cable plugged in the unit turns off the display. Communication with the unit has to be through the H.R.M. Manager PC program.
Dec 18, 2010 | Hyun Won Dual Sports DAH700 MP3 Player
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Zebra MT2070 Barcode Scanner  PN KT2070SD2078C1WW Barcode Scanner Logo
122 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
