Snapping noise and then quit
This is an older RCA 46 projection model # P46151wk. When I turned it on, it started to make a snapping noise and picture would blink very quickly. Within a couple of minutes it began to snap more frequently and then shut down into safety mode. Now, it will not come on at all. Can you advise me of possible things to check. Thanks
Doug
  • 8,617 Answers
Most likely items that will cause that are the HV distributor and the Flyback. You can get both those items at the following link. Just leave them a email with your model and chassis number off the rear tag and they will respond quickly.
http://servicemanuals.vstore.ca/
Posted on Jun 14, 2009
  • 431 Answers
Hi I am Vortash from what you are saying , this sounds like one of the tubes is arcing from the anode . They get damp or wet from condensation due to climate change etc and the electricity tracks to earth at High tension and it cracks as it discharges to earth . The possibility is now that has blown the oscilator transistor that boosts the power up to 19kv . I feel this one should be looked at by an engineer as you are dealing with the High tension end of the set .. Regards Vortash
Snapping noise then quits
Not sure what model yours is, but sounds like you have a bad start capacitor that has dried up or swelled and "snapping" when making connection. If you can give me the Brand and model number I can see what capacitor you need.
May 12, 2014 | Dometic Rooftop RV Air Conditioner
Model HO-0250H, heater makes a pair of snapping noises one after the other, perhaps from expansion/contraction. Heater is two months old.
The unit uses oil to create residual heat. The oil can contain small amounts of moisture and when the unit heats that moisture turns to steam, Steam has a great expansion ratio. When the steam condenses back to moisture it can conglomerate into large water droplets instead of being dispersed. This means that when it heats back up the steam expansion is more radical and makes noise. Unless the unit starts leaking oil, it is fine to continue using it.
Feb 20, 2014 | Pelonis Heating & Cooling
Model number p46151wk, can turn tv on with power button but automatically turns back off
A number of possible answers---I need to know two things= on back of set aside from model number is there a chassis number like PTK 195 etc? Is power light green and going off or remains on?
Aug 27, 2012 | RCA P46924 46" Rear Projection Television
GE D52GW12, picture is distorted and snaps
its either the HV splitter or the flyback which needs replacement. You can get both items at the following link with free instructions.
Mar 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Flicker after warm up
Arcing noise suggests HV leak--get a tech to look at set!
Oct 03, 2007 | RCA D52W19 52" Rear Projection Television
Snapping noise and flickering pic when set is first turned on
The hi voltage cable a red wire with gray cup that its attached to the picture tube needs to be sealed , that can solve the problem. 40.00 dls depending on the tech . dangerous to do without the knowledge ,picture tube need to be discharge before, try to seal to avoid accidental hi voltage discharge . if you need more help let me know
Jun 14, 2007 | RCA F27669 TV
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
