Purchased online a laminator but there is no manual it is gbc 2070 i need to use it
Need to know how to use gbc2070
SOURCE: GBC Eagle 35 Laminator heats up, won't turn
if you cannot get this fixed....i will buy it for spare parts.....408-802-3843
regards Cliff
Posted on Mar 15, 2010
SOURCE: i have a gbc heatseal h535 turbo laminator that
I had the same problem. It's prob the optical chopper/encoder wheel on the motor shaft that wobbled loose and scraped on the sensor until plastic filings plugged up the holes. remove cover and check the "u" type sensor the chopper wheel runs in. Mine was really crammed full of plastic so I had to take it it off and pick it out with a blade. when you reinstall make sure wheel runs between sensor with no scraping.
Posted on Apr 09, 2010
SOURCE: Seeking online owners manual for GBC Shredmaster 2260x
http://www.gbcconnect.com/assets/docs/2260X.pdf
Posted on Jun 03, 2010
SOURCE: need parts for a gbc docuseal 95 laminator
Go to http://www.mybinding.com/.sc/ms/ch/parts.html, and scroll down the list of products to "pouch laminators" then choose your specific model. When you click you can access parts information as well as a diagram of the equipment. Good luck.
Posted on Sep 07, 2010
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
We have a GBC 425lm laminator and everything works EXCEPT it won't heat up. Any ideas?
I am not sure if the circuit breaker controls just the heat but you can try resetting it. Either that or your heating element has died on you. Or if you have technical skills:
I took a look at the online manual and it was terrible. I hope these help.
Nov 16, 2017 | Gbc Office Equipment & Supplies
Replacing the fuse in an ultima 65 laminator
Hello, I found the service manual for the laminator.
https://www.manualslib.com/manual/838190/Gbc-Ultima-65.html?page=42#manual
page 42 shows the left side blow out. #16 is your 15A circut breaker, located on the underside of the left rear of the machine. Page 43 lists what all the numbered parts are if you need to know anything else. It doesn't give explicit instructions on how to remove, it but it shouldn't be difficult. Be gentle but firm and don't jerk it out or you might damage the connectors. Hope this helps.
Sep 27, 2017 | The Office Equipment & Supplies
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Need a break down manual for gbc h400
If what you are referring to is a laminator (??), I found manuals online at www.gbcconnect.com when I "Googled" the model name. Good Luck !! Jim
Aug 15, 2012 | Office Equipment & Supplies
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
76 people viewed this question
k24674
jasbo
jasbo
