Question about Vets Best Science & Laboratory
Desexing i need a price.
How do I program prices for departments on a samsung er 4940
you cant,you need to use plu's,everything has its own plu,go to your plu settings and start putting in the plu number(price look up),then you link each thing to the proper dept Samsung ER 4940 Cash Register Manual
Jul 17, 2015 | Samsung Retail Supplies
Can you program a Da 7p Plus coffee without the handheld programmer?
Saeco 7P+ pricing is set mainly without programer. The machine has 2 pricing points so the price of the beverages can be set to one of the two prices. To change which price point the beverage is assigned to you need to use the programmer. Price point 1 is the lower price and price point 2 is the higher price.
To change the price on all beverages, make sure there is power to the door. On the inside of the door the is a little circuit board with two red buttons. On the bottom side of that board is a little button that is normally black. Press this button and the screen should read 000. If you push up (which is the 1st beverage button) the screen will read 001 this is price point 1. Press enter (4th beverage button) to change the price and use the up and down keys (down is the 2nd button down).
To change price point 2 press cancel (3rd beverage button down) if your in price point 1. If your in the menu at 001 just press up again and the screen will read 002. Repeat steps above to change.
Normally all beverages are set to the same price, if this is the case than change both price points to the same price.
It is better to set price point 2 first as price point 1 won't adjust higher than what price point 2 is set at.
When done which the machine off then back on.
Have fun.
May 10, 2014 | Saeco Coffee Makers & Espresso Machines
Need to price one
You can buy one here. Given the age of this camera, there is a big price difference between new and used cameras. I suspect the price for a new one is still the price it was when it was introduced years ago. The price for a used one more closely reflects its current value.
Mar 27, 2012 | Kodak EasyShare C360 Digital Camera
Need to buy A Toyota Sienna A/C Compressor, where I get best prices on original one?
FYI - all Toyota parts are proprietary you need to buy the OEM PARTS. Most of the times I go to the Toyota dealership and try to make a deal with the parts sales person. You would be amazed that most of them will give you a nice price. Just let them know how much is that aftermarket price. Most of the times they will match the aftermarket part sell. s price. Or you could visit www.usatoyotaparts.com for a better price... I hope this helps
Aug 09, 2010 | 2004 Toyota Sienna
Looking for Fisher Price, I Can Play Piano manual
looking for Fisher Price, I Can Play Piano booklet. Need to know how to connect and use
Jul 31, 2010 | Fisher Price I Can Play Piano System
Need a batter cover for the fisher price soothing
I would call fisher price and see if they have a replacement cover for your soothing motions glider. Here is the contact number.
In the US and Canada: 800-432-5437
Thank you
Apr 29, 2010 | Fisher Price Baby Gear
I have jumperoo and need a replacement seat. It
You can contact Fisher Price through their website (www.fisher-price.com) or alternatively, pop into a local Fisher Price stockist who should be able to order in the spare part for you. I couldn't find any at all on eBay!
Sep 13, 2009 | Fisher Price Baby Gear
I Have a Casio TE2000 Till and I need to change prices on the 24 buttons that are programmed already to different prices. However, to me the manual makes no sense and I can only change the first button...
to change the prices on the preset buttons.
1. turn key to PGM mode
2. press 1
3. press sub total button
4.enter price( no decimals req)
5.press relevant dept button
6.press sub total button
the new price will now be programmed in.
Hope this helps
Regards
sapna
Jul 06, 2009 | Kitchen Appliances - Others
Add 20% uplift price to a pricelist in an excel spreedsheet
lets say you have the column B with the prices. Got to column C right beside the first price cell (I'll take B2 as first cell for example) which is C2 and type
=1.2*B2
Copy this formula in the column C all the way down to the last price Cell. That will give you all the updated prices.
Before you delete the column B where all your old prices are you need to do one more thing. Select the entire C column (new prices) go to edit and click on copy. Before you click anywhere else go back to edit and click on paste special and select value. This will change the formula cell you have created a minute ago to a value cell. Now you can delete the old prices. Good luck :)
Feb 25, 2009 | Computers & Internet
Science & Laboratory Logo
78 people viewed this question
Top Vets Best Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Vets Best Science and Laboratory Expert? Answer questions, earn points and help others
